How do you turn off the safety lock feature
Im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Child lock
the door is closed.
"DRYNESS" buttons.
SOURCE: Can't deactivate child lock on washer
Try: Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
SOURCE: child safety lock
Press "end of cycle" button for over 5 seconds, the child lock comes off. All the best, and dont forget to RATE me.....
Press it again and the child lock comes on, simple eh?
SOURCE: LTF6700FS - (affinity) front loader - door lock
Sheck the hinche if is twist or pull that the most comon problem. If is that, disconect the door ahd replace the hinche. If the hintch is OK sheck the lock set up if is of place. Some time is being forced to open or to close it and bend the lock clip.
Testimonial: "This needs to be added to the Trouble Shooting guide of the manual. This is exactly what I was looking for - THANK YOU!"
YES. You can bypass this feature pretty easily. There are two wires going to this little device. Pull the two wires off and use a wire nut to "wire" them together.
Be sure to unplug the dryer as you do this work so you don't get a serious shock.
