Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
Posted on Dec 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mine alway,s freeze up and well stop working
I been told it need,s cleaning & little maintenance i don,t know what to do so all i want to be step by step answer thank you for the help
howard thompson
Level 2:
Novelist:
Champion:
  • Ice Expert 373 Answers
  • Posted on Jul 09, 2014
howard thompson
Ice Expert
Level 2:
Novelist:
Champion:
Answers
373
Questions
Helped
249233
Points
454
Cleaning should be performed every 6 months. 1. Harvest problems may occur if the following procedures are not preformed every 6 months. 2. Remove the ice machine front panel. 3. Make sure all the ice is off the evaporator. If ice is being made, Wait for cycle completion, then turn the machine "off" at the ICE/OFF/WASH selector switch. 4. Remove or melt all ice in the storage bin. 5. Add recommended amount of NICKEL SAFE ice machine cleaner to the water through according to label instructions on the container. 6. Initiate the wash cycle at the ICE/OFF/WASH switch by placing the switch in the WASH position. Allow the cleaner to circulate for approximately 15 minutes to remove mineral deposits. 7. Depress the PURGE switch and hold until the ice machine cleaner has been flushed down the drain and diluted by fresh incoming water about 15 min. 8. Terminate the wash cycle at the ICE/OFF/WASH switch by placing the switch in the "OFF" position. Remove the splash curtain and inspect the evaporator and water Water spillway to assure all mineral residue has been removed. 9. If necessary, Wipe the evaporator, spillway and other water transport surfaces with a clean soft cloth to remove any remaining residue. If necessary, remove the water distribution tube, disassemble and clean with a bottle brush, Reassemble all components and repeat steps 2 through 7 as required to remove residue. 10. Turn off ice machine water supply and clean the water trough thoroughly to remove all scale or slim build - up. If necessary, remove the water trough to reach all splash areas and float.11. Prepare 11/2 to 2 gallons of approved ( EPA/FDA) sodium hypochloride food grade sanitizer to form a solution with 100 to 200 ppm free chlorine yield. 12. Add enough sanitizer solution to fill the water trough to overflowing and place the ICE/OFF/WASH switch to the WASH position and allow circulation to occur for 10 minutes and inspect all disassembled fittings for leaks. During this time ,Wipe down all other ice machine splash areas,Plus the interior surfaces of the bin, deflector and door with the remaining sanitizing solution. Inspect to insure that all functional parts,fasteners,thermostat bulbs (If used ), etc.are in place. 13. Depress the purge switch and hold until sanitizer has been flushed down the drain. Turn ON the ice machine water supply and continue to purge to the diluted sanitizing solution for another 1 to 2 minutes. 14. Place the ICE/OFF/WASH switch to the "ICE" position and replace the front panel. 15. DISCARD THE FIRST TWO ICE HARVESTS. If this dose not help your problem let me know and we can solve it.
Front wipers don't work
Take it to a repairs shop,if you have to ask
& have no auto experience
1helpful
2answers
My hot water heater will not ignite it stopped working overnite? its a whirlpool 50 gal model number BFG2J5040T3NOV
Sounds like the thermal couple may be shot I thought that was the problem with mine but it needed air to supply the burner I took the cheap steps first like working on a motorcycle or car I know that you can buy the whole burner with the thermal couple assembly, I got mine from a plumbing company it was used but in better shape than mine if its not very old it can be fixed I KNOW mine is working just fine!! Beware of the plumbing companies the will give up and try to sell you a new one to skip the grunt work really isn't as hard as it may seem!! What have you to lose???
Which way do turn the rear shoe and drum brake adjuster after putting new ones on
You turn the adjuster by hand or with pliers
Then slide the drum on & off a few times, until
the shoes are just touching & barely making a noise
Each side will turn opposite,you don't need to know the
direction,just adjust & try the drum on
You either have to have the drums machined or use a dremel
tool to grind off the step, or what I have told you & done for 48
years won't work
This is my problem: yesterday, I had to have the alternator and battery replaced in my 2008 Solara convertible. I purchased the car new in May 2009 & it has 40,000 miles. I had the work done at Mieneke...
Hey Lyn. Regular maintenance is a scheduled procedure recommended by the manufacturer. They don't check everything every time. If you would want them to do this and create a list of things checked , I am sure they might, but it will probably cost you more. People assume that because they take their cars to dealerships , that they get the best service available. This is not always true. If the battery and alternator are bad again, I would go back to mieneke and complain to them. they are nation wide and all of them should honor a warranty. What mieneke told you was probably opposite of what happened. The alternator was probably putting out to much of a charge and toasted the battery. Weak batteries wont kill an alternator. At least I have never seen or heard of it. As far as warranty issues, it is pretty much your responsibility to bring them up to the dealer. Again if there are specific things you want checked at maintenance time take a list and have them sign off on it. If they already have a list ask to see it and when there done ask for a copy. you pay for it, so they should give you one. I suggest that if you have an issue come up with repairs, to post on here and get some insight to what may be going on with your car. There are a lot of good mechanics on this site. Randy
When I turn it on, the blade is slow to take off turning. Sometimes it just won't go at all, so I turn it off so as not to burn up the motor. Does it need cleaning, oiling, or something else?
If you don't have the original paperwork for maintenance for the ceiling fan this is what I would suggest: Cleaning and adding lubricant to the fan's main stem.
Put some lubricant on the fan stem: a drop of oil / graphite grease will do it.
First turn OFF the power, AT THE CIRCUIT BOX - BREAKER BOX.
SECOND Get a household or larger step-stool sized ladder 5 - 6 ft - set it up by your fan, clean the stem around the blade area, wipe gently with a Swiffer duster pad (those pink & white loopy-looking pads, they come in a kit in cleaning supply section of store -- with a slide-on plastic handle, & refills).
These REALLY do work to attract the majority of the static-oriented dust that is so common on electronics.
Then :
Clean and dust off all the blades, (if wood a drop or two, of a Murphy's oil soap will keep them looking nice).
So - clean them - add the Murphy's oil soap, using a small spoonful to 1/2 cup of warm water. Mix in an empty 'Cool Whip' (or similar sized container).
And place that on your small ladder on the ladder's shelf; for ease of use -- no pesky buckets to worry about getting knocked over -- (then start to clean using a rag made from an older smooth cotton sheet, or a really worn towel that has VERY little 'lint producing' potential, (the less junk you add to this cleaned fan the better) as to ANY lint on towel or cloth residues) -- wipe carefully, working slowly -- all the surfaces of the wood!
Top, bottom and those PESKY thin edges. That way you won't be fighting extra dirt in your eyes as you try to tackle the other problem! Dry off the blades with a clean cotton rag made from a sheet. Gently, no hard rubbing needed,
Ok, so NOW you are done with the fan blade cleaning, I bet it looks nice!
Add the oil: a drop of WD40, a household oil in a metal skinny can with a progressively graduated 'needle' like top (or a small dab (using a paintbrush dedicated to that use) of graphite grease -
Some hardware stores sell it in small tubes ... (or small containers like the size of sterno fuel jars) ...
You don't want any motor running without adequate lubrication, or they run 'hot'. Then they can start to cause trouble.
Add the graphite or WD40 to the stem, let it 'run' down the stem & add a 'little' more, but not too much as to 'flood' the area below where it is needed or 'flowing' to ... before you climb down the ladder and go to turn it on -- look to see if the oil has run the length of the rod, is allowing easy movement, as to turning of the blades.
Check it manually by pushing the blade in the direction the blades are set to go, by pressing the fan blades to move forward with a flick of your fingers. They should move easily without hesitation.
Look above and below the blade location as to connection of the blade on the fan rod or stem itself, to see if all oil needed is present; stem is not appearing overly 'dry', or too 'wet' either.
When that is done to your satisfaction, climb down from the ladder, turn on the fan, let it run for a while on the LOWEST speed setting, then check back like in perhaps an hour. AS to if it needs another oil addition.
If not I'd say start out on low always to turning it on, then change to medium speed or high only later.
You don't want to start off on the highest setting each time you use it. That is a likely way to burn out a motor.
If it is running 'smoothly' without 'wobbling' or smelling 'hot' as to an electric motor that is laboring, then you are in business!
Proper maintenance is 'always' welcome if you want your appliances & fans to last ...
Highlight these instructions in yellow sharpie - if you print a copy to use, as to steps that worked well. Then follow those every time from now on.
CLEANING THE FAN at least once or twice A YEAR for basic maintenance that will save you stress, money in the long term (it won't need replacing) and help keep you cool ...!
So ENJOY your fan and the coolness it delivers!
Aug 21, 2011 • Dryers
I have a 1994 Chevy extended cab 4WD 1500 pickup with an intermittent problem with the windshield wipers. Sometimes they work and sometimes they don't. A friend of mine told me that he had a similar...
I have experienced this problem with 80's and90's chevy trucks especially with the Delay part of the wipers. Almost always it has been a dirty or corroded connection At the wiper motor. Unplug the motor and check the connections at all plugs. They Should be clean and make a tight connection. This usually solves the problem. Once the connection is cleaned use a little dielectric grease or wd40 on the connections When reconnecting. Let me know if that works for ya.
I have a 2002 ford zx2 with a little over 100000 miles. I was told the only thing necessary for a tuneup would be new plugs. Is this correct?
In my world your correct
Tune-ups have been gone for 25 years,
as computers do all the tuning
Spark plugs are all that is left & they are
called preventative maintenance, as they
always were.
You can do air filter,gas filter,clean MAF Sensor
etc, but not tuning anything,just restoring things
1helpful
Won't play ps2 games
take the Ps2 gaming console to nearest Sony service center the problem is with lens it sometimes run quiet well but sometimes got hang you can do one little thing & try it take any of the Ps2 games which are getting freeze while playing take Colgate toothpaste the regular one take a little bit of it & apply on the game disc rub it on the disc & then clean & wipe out with a clean smooth cloth & clean properly after cleaning the disc will look good neat in condition but please make sure no particle is left after cleaning & now play the disc on Ps2 & see if it still get freeze then their is a problem with console better check it at nearest Sony service center for trouble free working
1helpful
Paper jamed always
clean all roller & sensors properly . if you don;t know how to do it read manual
1helpful
4answers
My game freezes at the same spot every time
First step should be to change the game by the new one (or clean the disc). If this still not help please advice.
Top Ice Kitchen Appliances - Others Experts
vince
NOEL
NOEL
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
