Question about New Bright Toys
Need a 9.6v nimh for fat boy motorcycle remote control by harley davidson
Radio controlled red motorcycle
SOURCE:
Pyrhyc
  • 2028 Answers
SOURCE: 1995 fat boy- harley davidson
This is going to be a problem that will need to be tracked down because there are several things that could cause this. It's going to be in the electrical system, and any one or combination of the following can cause this, Faulty switch, especially the ignition switch, bad wiring which could be a bad connection, loose ground, bare wire, or broken wire, These are the two cheapest, but the hardest to find. Now, it can also be a bad or malfunctioning ignition module, coil, voltage regulator, and magneto assembly. You will have to test each of these. I recommend that you start at the spark plug end and work your way back since most of this is in line and work in conjunction with each other. Keep in mind that this being an intermittent problem, it may be extremely hard to find.
I also have a 95 Softail, and recently had a similar intermittent problem, turned out that there was a hairline crack in the regulator, and the problem would only occur if the regulator was warm enough for the crack to open a bit. I also traced the wiring harness, found and replaced several wires that were in bad shape, thinned, stretched, corroded, etc... You will be amazed at how much wear the wiring harness will have on a 13 year old bike.
Don't let this discourage you. In my opinion, the mid to late 90's models are the best HD ever built, and the Evo is by far the best engine. With the newer bike you have to worry about things like, crank and cam sensors, ECM's, fuel injection, and all the other electronic BS. It's to the point that the average rider can't work on his/her own bike, which is getting away from the HD tradition. That's a great bike you have, keep it for a long time. I may buy a newer bike someday, I don't know, but I do know that I will always keep my 95. Good luck with this and be safe.
Posted on Sep 16, 2008
  • 22 Answers
SOURCE: oil come out the air cleaner
Too much crankcase pressure or the breather pipe is split/dosconnected. The crankcase breather goes into the rear of the air filter and the crankcase gasses are drawn in to the cylinder with the gas/air mixture and burned
Posted on Nov 10, 2008
  • 2712 Answers
Posted on Nov 20, 2008
Mitchy123
  • 216 Answers
SOURCE: correct torque for rear axle nut on 1997 harley davidson fat boy
Harley manual says 60-65 ft lbs... do NOT exceed this or wheel could seize
Posted on Apr 04, 2009
OneRide
  • 384 Answers
SOURCE: 2001 harley davidson fat boy fork seals leak
Either the seals were not installed correctly or your tubes and sliders are excessively worn. Not changing the fork oil at recommended intervals will cause excessive wear. Overfilling the forks will cause leaks too.
Posted on Jun 04, 2009
2003 Harley Davidson FLSTFI Fat Boy starter relay location
Hi, Shane for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
2003 Harley Davidson FLSTFI Fat Boy starter relay location Google Search
https://www.jpcycles.com/2005-harley-davidson-softail-fat-boy-flstf/starter-relays
99 to 05 Harley Softail Service Manual pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
2005 Harley Davidson Fat Boy Owner Manual
Aug 05, 2018 | 2003 Harley Davidson FLSTFI Fat Boy
2000 Harley Davidson FLSTF Fat boy does it come with cv carburetor
Hi, Kyle yes it does, for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day. Harley Davidson FLSTF Fat Boy 2000 Motorcycle Photos and Specs
Harley Davidson Softail Workshop Service Repair Manual 2000 2005 $7 very cheap
Instant Tech Relief To speak to me personally $6 very cheap
Feb 25, 2018 | 2000 Harley Davidson FLSTF Fat boy
What is the red light for opposite my 6 th gear green light
Hi Harry, for more information about your question please visit the website below. Good luck and have nice day.
Controls and Indicators
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 17, 2013 | 2011 Harley Davidson FLSTFB Fat Boy Lo
No alarm system installed but red light is on
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
Aug 11, 2013 | 2011 Harley Davidson FLSTFB Fat Boy Lo
How do you repair trip meter on a 1991 Harley Davidson Fat boy
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Need help with trip meter reset knob Harley Davidson Forums
May 28, 2013 | 1993 Harley Davidson FLSTF Fat boy
I need manual for 2010 Harley Davidson Fat Boy Lo
Harley Davidson Manuals Mark Workshop
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Dec 19, 2011 | 2011 Harley Davidson FLSTFB Fat Boy Lo
Need a wiring diagram for a 94 harley fatboy (flstf) to wire in turn signal control unit.
Hi Johstonrod, for a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Apr 25, 2010 | 1993 Harley Davidson FLSTF Fat boy
I need a diagram of brake system for my 1994 Harley davidson fat boy
The wiring is very simple. The switches get power from the orange accessory wire. When the switch is closed, it powers up the red wire going directly to the brake light bulb.
Apr 18, 2010 | 1993 Harley Davidson FLSTF Fat boy
Toys Logo
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
