Virus on hard drive so I put in a new one with a fresh operating system windows vista now it wont even bring up boot menu. Have tried switching sata ports hardrives and the power switch connetions
You go to AVIRA dot com and download the boot tool, or go to BITDEFENDER and run an online scan, you don't put in a new HDD just because you had a virus, it sounds like you had a problem and thought it was a virus.
Read you manual, plug in the Sata drive into Sata 1.
Do you mean BIOS post, if you don't even see the BIOS post, check your monitor with another PC.
There is only one correct power switch pin, a , + and - pin, how can you switch, there is no such thing as switching.
SOURCE: asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
SOURCE: ASUS M2N-E SLi Motherboard No Graphics
I have the same board (M2N-SLI) with a BFG 9800 GTX with no video either. I have the card in the black slot and I have 2 mem sticks in the yellow. Shouldn't make a difference if I'm using a monitor not an LCD right? Everything spins up for me too, hard drive, vid card has power, CPU fan is on, post (green) light is on.
SOURCE: asus p5kpl-am in USB and Sound not detectiing
try to make an adjustment on your bios i think usb is disable try to enable it and sure all your usb will work.
SOURCE: IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
