After running diagnostics i got error code e5e looking the code it said a communication problem refer to test 11 . what is test 11. i unplug the machine an plugged it up again . now I get error e41. help
SOURCE: Frigidaire GLTF2940ES0
remove the bottom panel will find a tech sheet there with more specific instructions and the speed control bd is under the tub on the left hand side unplugged the unit before checking and the door lock is part of the com system turn the washer and see if the door lock light comes on try to open the door with the light on if you can that's where the problem is
SOURCE: Washing Machine starts, squirts water, then stops.
E5E IS FOR Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
SOURCE: Frigidaire Front loading washer error codes E41 and E20
Hi
E20 is a drainage error. If there is water in the drum make sure the discharge pipe at the back of the machine is not kinked or blocked. You should also check the pump filter is not clogged - this is behind the front panel underneath the drum at the front of the machine.
E41 = Control board thinks the door switch is open. This points towards a faulty door switch on the machine.
Hope this helps. Please remember to rate my answer. Many thanks.
If your machine is stuck on the drain sequence or you read error code E20, the filter basket is probably clogged:
You will need a pair of slip-joint pliers and a Phillips head screwdriver.
Before beginning any work, make sure to unplug the machine from the electrical outlet.
**Note: It may be easier to perform this task with the washer lying on its side; therefore it may be necessary to disconnect the water lines from the machine.
1: Take off the front kick plate (two screws at the bottom of the machine).
3: There is a black accordion hose with two clamps.
2: Have a towel ready to catch the water that leaks.
4: Remove the clamps at each end to access the filter basket.
5: Stick your hand inside the hose and remove the plastic filter basket (it will probably be clogged with hair, lint, fabric).
6: Thoroughly clean the filter basket and remove all debris from the inside of the black accordion hose.
7: Replace the filter basket.
8: Reattach the black accordion hose at both ends.
9: Secure the clamps at each end of the hose.
10: Wipe up any water that may have spilled inside the machine.
11: Reattach the front kick plate with the two screws removed earlier.
12: Reconnect all hoses before plugging in the machine to the electrical outlet.
** This took me about 30 minutes from start to finish.
Hey friend, thanks for your inquiry!
I see your Frigidaire washer is displaying an error code "e5e". However, it appears "e5e" is an invalid error code. Let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display "e5e" you may want to seek assistance from a professional for proper repairs. -Matt
Hello friend, thank you for your post!
Please help me understand the question you are asking about your Frigidaire washer. Is your washer cutting on and off? Or is it coming on without any one pushing start? Is it flashing an error code? Thank you for any additional information you can provide. I look forward to your response. -Matt
Hello barnessursula - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However, if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Hello Ivan Kelly - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. If the wiring is bad, it has to be corrected. However if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Hello jsw1993 - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Supposing that the wiring is bad, it has to be corrected. However if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
