I revcently purchased a gamecube from ebay that has the video screen attached. The larger connection goes in the back of the cube where the cord to the tv would go but I have no idea where the other cable goes{the one with the tv cable looking end. please help me
The Intec Gamecube screen requires both a 12 volt DC input and the AV input. The larger connection is the AV cable which plugs into the back of the Gamecube console. The smaller round cable is the 12 volt DC input cable that goes to the power source for your screen. The solution is to either get the original splitter cable that splits the DC power to the screen and the Gamecube, or use separate 12 v DC inputs for each device. These original Intec splitter cables are rare and are not cheap, and the only place I have found them for sale is at the NES Repair Shop:
http://nesrepairshop.com/online_shopping/index.php?productID=645
The only other solution is having separate 12 v input cables for the screen and the Gamecube. And finding the right size (very small) is also a task.
If you don't have the money for the splitter $50+ and want to try using two separate power sources a wd external hard drive power cord will work. I had model number ksas0241200150hu work. Sells on Amazon for $7
Here i hopes this helps
There should be more connection slots in the bottom.
