*Beeping* thing Hobart SR-24 Dishwasher Beeps at me.
Has beeped on startup since service tech was here last month...thought he fixed something we didnt even know was broken.....but now the thing beeps mulitple times a day...sometimes mulitple times in one cycle.
What does it want?
Quite possible that the program controller unit is faulty and must be replaced.
make sure the motor is good as well as the pumps before the conroller can be checked externally for errors to finalise.
the p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ON THE UPPER RGT CORNER OF BSTR YOU WILL SEE THE THERMISTOR.unplug from harness use7/16 wrench to unscrew from bstr. well,get new therm.and installyou can get @ any hobart office in your area, part#328994. dont forget to vote, thanks, monomoy
Depending on how often you delime the dishwasher use 2 cups.The delime light will come on after 1000 cycles set from factory default.If the delime icon is lit and beeps,turn the unit off.
Push and hold the delime/wash button and on button for 5 seconds and youll be in delime mode.
The unit will fill and heat up and display "add delime".Open the door add the delime and press the wash button.The dishwasher will run for 5 minutes then rinse and drain twice then shut off.When you turn it back on the delime icon will be gone.I'm a hobart tech and repair these dishwasher often,any questions let me know and please rate me,Thanks.
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
