Advent 4211c Notebook Logo
james simpson Posted on Dec 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Advent 4211 screen to base connection problem
Screen goes black having to keep adjusting the screen angle to get it on again
joecoolvette
Level 3:
  • Advent Master 5,660 Answers
  • Posted on Dec 15, 2012
joecoolvette
Advent Master
Level 3:
Answers
5660
Questions
0
Helped
2192874
Points
18014
Video Cable
The Video Cable connects to the motherboard.
It then runs along under the Left Hinge, and connects to the back of LCD screen.
{LED backlighting. Does not use a screen Inverter]
Due to just normal opening, and closing of the laptop; the Video Cable may be pinched.
This can cause the connection of the Video Cable TO motherboard, to be loose; and/or LCD screen.
Solution is to partially disassemble the laptop, and PHYSICALLY make sure the connection at motherboard is tight.
Visual inspection will NOT do.
Connection at back of LCD screen needs to be Physically checked also. (Try to plug in tighter)
Also visually inspect the sheath of the Video Cable, for apparent signs of damage.
Any signs of damage to the sheath, may mean damage to the tiny wires inside the Video Cable.
(Stretched/Broken)
Also due to the age of the laptop, suspect cracking of the insulation, of the wires inside the Video Cable.
If you have a multimeter, set it to OHM's (1K), and check continuity of every wire in the Video Cable.
Or take it to a small computer store, and have the resident tech check it.
The Advent 4211 is just a rebadged MSI Wind U100, according to my findings,
Disassembly guide,
http://www.bit-tech.net/hardware/laptops/2008/07/05/breaking-wind/1
That's the problem, the Video Cable,
http://microdream.co.uk/advent-4211-c-lcd-screen-cable-k19-3030019-h58.html
[ In the photo, the large connector at bottom plugs into the LCD screen.
The smaller connector at the upper right plugs into the motherboard.
The separate black wire you see with the eyelet on it, is a Ground wire ]
For additional questions please post in a Comment
Regards,
joecoolvette
5 Related Answers
Anonymous
  • 476 Answers
  • Posted on Aug 16, 2009
SOURCE: My Advent 4211 netbook connects wirelessly to the
if you ran your network wizard to get the internet access shared then you should be able to share your files too.
and folders the same way ,
go to my network device,
veiw network computers,
if you can see the computers desk top then
go to Shared folders and try to see if your folders have been shared open something.
If you can see the desktop and not open the shared folders then run the network wizard again,shutdown and restart,to save your settings,
to share files between both machines you will need to drag the file into my shared folders or rightclick on the file your sharing and click on sharing,follow the prompts to share and that should fix your problem.
Please rate me thanks MISTERDJ
Anonymous
  • 24 Answers
  • Posted on Dec 27, 2009
SOURCE: reboot an advent notebook to original settings
the computer shoulda came with a disk and that would be your operating system disk so put it in, then start your computer and if it doesnt boot to the disk, then hit F2 and change the boot options and make it boot from the disk and so when it does boot, then thats when u can reinstall windows back to factory settings but i dunno about advent notebooks. in HP tho, u can do it from the start menu cuz the reinstall settings are already on your computer so ya dont need the disk
Azrael SRL
  • 11800 Answers
  • Posted on Oct 26, 2009
SOURCE: I have an Advent 4211 Netbook. When I switch on
XP is corrupted, most likely caused by a massive infection. Try a Repair. Follow this instructions http://michaelstevenstech.com/XPrepairinstall.htm
If this doesn't work (or goes back they way it is now very quickly) use a Linux Live-CD to backup all your files and reformat your pc and do a clean install.
Anonymous
  • 20 Answers
  • Posted on Jan 03, 2010
SOURCE: battery is not charging
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jodiki20
Anonymous
  • 47 Answers
  • Posted on May 29, 2010
SOURCE: cannot get my wifi to work onmy advent 4211-b
Hi! Try to use the function key: FN+F11 to enable the wireless adapter. Check device manager if driver is properly installed.If yes, try to update the driver:right click on the realtek wireless LAN in device manager and then choose properties and then click update, choose automatically look for update from internet.If this doesnt work try to uninstall and reinstall the driver (make sure you restart the system after reinstalling the driver). If you have AVG as your anti virus sw try to disable it or uninstall it and then check if it will work.hope this will help...
Advent 4211
The Boot Manager file may be corrupted or as it says missing. You must reinstall the operating system. Use the hidden recovery partition if it (still) exists or the recovery media that shipped with the computer. If no recovery media came with the computer, you must contact the Vendor and order them. You will in all likelihood have to pay for them.
1helpful
Hi! I can't find any way to get my Advent 4211-C (Windows XP OS) webcam working on Skype (the only webcam function I currently use). Cyberlink says there's "No available Captured Device". I don't...
Advent 4211 always require you to enable it everytime you turn the laptop on. it is Fn key + F10 I think. Look for the Function key at the top of your keyboard which has a picture of a webcam. Hold down the FN key at the bottom left, and then click on the correct 'F' key. You should see a little picture come up on the screen to say you have enabled your webcam. That should work.
I have an Advent 4211 Netbook. When I switch on windows XP will not start, just takes me to the screen which offers Safe Mode, normally etc - but whichever I try it just comes back to this screen
2answers
Need advent 4211 keyboard
Checkout www.partmaster.co.uk
This is the spares departments for DSG who advent computers are manufactured for. Hope this helps :o)
Advent 4211 Bluetooth Wifi problem
HP very recently has had problems with the actual wireless hardware. I found out when troubleshooting a friends HP laptop. Check for information on HP site to see if there is a recall.
2helpful
1helpful
How do I connect to web?
As far am I'm aware the Advent 4211 netbook is not able to connect to the Internet 'on it's own' as such. Unfortunately the word 'netbook' has been advertised with this product in many PC World stores giving the wrong impression.
The best and easiest way would be to look into mobile broadband solutions.
Of course, it wouldn't do any harm to try out your Vodafone USB on their laptop to make sure it works well enough! :)
Top Advent Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
