RT/SIG fuse #11 15amp - I/P fuse box .
Fuse Block - I/P
In the center of the instrument panel, beneath the right side of the radio, in back of the right side console access panel.
This fuse is power to the BCM , When you put on the right turn signal , this is a voltage signal to the BCM . With logic ( programming ) the BCM then controls the turn signal !
Turn Signal/Hazard Lamps
The body control module (BCM) is responsible for controlling the turn signals and hazard lamps. When the turn signal switch is placed in either the left turn or right turn position, the BCM receives a signal from the turn signal switch. The BCM then sends an on-off voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator. When the hazard switch is pressed, the BCM receives a signal from the hazard switch. The BCM then will send an on-off voltage signal to all the turn signal lamps. All the turn signal lamps will flash including both IPC turn signal indicators.
There could be a DTC- diagnostic trouble code stored in the BCM pointing to the problem ! I suggest you take your vehicle to the dealer or a ASE certified repair shop that has the diagnostic tools to find the problem . Just so you don't waste your money replacing parts that don't fix it.
There could
SOURCE: left rear turn signal light on my 1999 chev. s10 is not working
any increase in bink speed is direcly related to a bulb being burt out.
SOURCE: Chev Cavalier 2003 only one rear turn/brake/hazard light
I have a 2002 Chev Cavalier that had the same exact problem. I replaced the bulb harness (purchased from a chevy dealership for around $5) which was fairly easy to do. I have had zero problems with it since.
SOURCE: No rear brake light / turn signals on 2001 Chevy Cavalier
The problem is the turn signal/headlight/hazard switch assembly on the steering column which the brake light wiring runs through. The part is easy to change and cost about $50 at most parts stores
SOURCE: no turn signals or side brake lights on 94 chevy suburban
the problen is probably the turn signal switch with a test light check for power at brake switch if no power check for power at turn signal switch the brake lights are incorperated through the turn signal switch
SOURCE: Tail lights don't work on 1998 Chevy Silverado.
check the wiring from the tailights back to the fuse panel, it sounds like an open connection. if i recall correctly check under the dash on the drivers side near the fuse panel for a bunch of wires in a bundle and look carefully for a wire or two that are cut/shorted/or seperated, you can also check under the drivers side kick panel by the hood release.
