Disney 13" TV Logo
Posted on Jan 14, 2009
Code for p1300ntv to work with directv remote
I'm trying to find a code that I can use to program my directv remote to my disney 13" princess tv, any suggestions?
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jan 16, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
4257
Points
18
You can "manually" find your code by  1. pressing tv button on the remote 2. press and hold setup until TV button blinks twice 3. press 991, the tv button should blink once 4. slowly press and alternate the power and tv buttons until tv turns off.   5. press setup to lock in the code when tv turns off.
hope this helps,  j
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 26, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2064
Points
My son has a Disney Cars TV. Used the code for a Phillips TV 11454 , I don't know if the Princess TV's were manufactured by phillips. The back of the TV listed Memcor as the manufacturer.
Universal remote code
disney 13" princess tv, any suggestions? You can "manually" find your code by 1. pressing
Trying to program a universal remote for the Disney Princess TV, Model P1300NTV. I need the name of the manufacturer so I can get the proper codes.
Try http://www.tacktech.com/display.cfm?ttid=145.
"If you are having difficulty identifying a component or peripheral you may be able to obtain company information by entering the item's FCC ID number" on their website. "The first three characters are the company Grantee Code. The next character(s) (1min to 14max) are the Equipment Product Code (EPC). Include -'s."
Good luck and please post back that you are successful and click thumbs up of your success or that I can be more helpful.
I have a Disney princess tv but cannot program the direct tv remote. Is there a code I can use? I can't change the av on the tv without its own remote and that was lost by its 3 yr old owner!!
This tv is made for the Disney corporation by some small company.There are no codes or any kinds on codes for this tv out there.But u still can buy the original remote.Try website like Remotes.com to buy an original remote.
Remote for disney princess p1300ntv television broke. i bought new "universal" remote and need code for tv. this was manufactured by starlight and the code provided in guide to new remote doesn't work on...
Try Remotes.com to buy the original remote,will never worries about codes again.This tv was manufacturer by some small company for Disney corporation,that why very hard to get the universal codes to when the tv is old.
Have a Disney modle tv and need the code for a remote the remote is not working now modle # P1300NTV
Try setting it to cable remote--see manual or check back label for manufacturer's parts and accessories phone number.
15helpful
3answers
I NEED A PROGRAM CODE FOR A DISNEY TV
I had the same problem I used code 10463 and it worked...My daughter has a Disney Princess TV model DT1350P. Hope this helps.
Disney 13' Princess tv
You've tried all the codes for your TV, but you still cannot get the remote control to operate your TV.
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
Hope this helps
8helpful
4answers
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
1helpful
Tv does not have sound
change the speaker it's busted .
5helpful
8answers
Universa remote codes.
I used Memorex code 135
Top Disney Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
