1996 Ford Taurus Logo
Posted on Jan 14, 2009
97 taurus will not star in cold weather
I have a brand new battery and spark plugs and my 97 E85 Taurus will not start in cold weather even when I had AAA jump it can anyone help me with Ideas on how to solve this problem I have already had it in the shop 2x this month
Damsel in distress
  • Ronnie Wilson May 11, 2010
    The Engine Acuators & Sensors All Have a "BASE" Setting for cold Start, Witch in Basicly Full RICH Setting. Rich=MORE FUEL and "LEAN"=Less. You Did not say or may I ask if this "SHOP" found ANY Trouble Codes? if so What Are they ? check Engine Light EVER Iluminate while Running ??? Any Repairs Performed on the 2 Past Visits at "SHOP" ? I Want to help you but Need This type of INFO from you. Thanx,,,,,,,RejakWilson
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 30, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
744
Points
I had this problem with my 98 taurus i tried jumping it wouldn't start, mine was the fuel pump check.
1999 ford Taurus will not start when temperature is extremely cold. battery is new, starter checks as good as well as alternator. once temperature warms up into mid 20's usually will start again. car...
test the battery when cold as it could have a problem only when very cold, what condition is the plugs in and the ignition system which can cause a problem.
2answers
1996 using E85 because Ford encourages you to do so
No 1996 vehicle uses E85
That product wasn't even thought of or
available until a few years ago
The is 85% Alcohol & will ruin your entire fuel system
The car wasn't designed for that fuel,no idea why you
would even go there,just silly
My '97 ford taurus isnt kicking over while tryn to start it up
Anything done to car, or happened recently that might affect this?
If starter fluid doesn't work, and starter is cranking normally (too fast may point to a timing belt broke, too slow may mean battery run down and not producing sufficient spark), there's still a problem in your ignition. Pull a sparkplug or two. After cranking a little they should be wet with gas. Check for compression while a plug is out: hold your finger over plug hole when cranking. You should feel pressure buildup and release over and over as long as cranking.
A properly timed engine needs spark, fuel, and compression to start. Keep reviewing your procedure. Something is not right.
You may want to have the computer scanned for possible trouble codes. Check plug wires for proper routing. Were plugs gapped right?
I have a Taurus which turns on occasionally....doesn't start in the cold
Have you changed the spark plugs lately? Usually hard starting in cold conditions is caused by worn spark plugs.
1995 ford taurus will not start
a faulty coolant temperature sensor could be at fault. if its telling the computer the engine is hot when its actually cold, it can cause performance problems. when the sensor tells the computer its cold, it richens the fuel mixture. once the car warms up, it leans the mixture out. if the mixture is too lean at startup, it will run poorly
Starting problems w/97 ford taurus
check for spark and check to see if its getting fuel.
2answers
97 ford taurus GL idles and kills when putting it in gear
check the vacuum hoses and make sure none of them are off and check the timing and also the drive belt
97 ford taurus idles and kills when putting it in gear
check the vaccum hoses to make sure none are off and check the timing and also the drive belt and also check the vacuum hose behind the throttle body
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
