Cars & Trucks Logo
Dave Simpson Posted on Dec 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't start easily since it got cold (32degrees). It's fine once it starts
Cummins Engines, Smokes as it is turning over.
raj somaiya
Level 3:
  • Dodge Master 5,370 Answers
  • Posted on Dec 14, 2012
raj somaiya
Dodge Master
Level 3:
Answers
5370
Questions
0
Helped
3570253
Points
14579
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
5 Related Answers
hotrodtod38
Todd Bradshaw
  • 141 Answers
  • Posted on Feb 14, 2009
SOURCE: 2004 cummins diesel intermittent no start
GLOW PLUGS ?
Anonymous
  • 246 Answers
  • Posted on Nov 12, 2009
SOURCE: 02 dodge dakota 4.7 v8 starts then dies when cold
Have your battery tested. It might have a bad cell causing it to not have enough "COLD" amps of cranking power.
Anonymous
  • 373 Answers
  • Posted on May 16, 2010
SOURCE: 1997 dodge cummins at times won't start can happen
Purge the air out of the fuel lines at the filters and pump. Some times it's easier to crack open the bolt on top of the injectors one at a time to remove the air bubles traped between the pump and injectors. You might want to check the ohm resistance on fuel heater. Using a ohm meter connect to the two wires connected to the heater, the ohm reading at 40 degrees will be 1 ohm. and at 80 degrees it will be 1,000 ohms. If not to this scale replace the fuel heater. If no power to heater look at the relay next to the brake master cylinder. Hope this will help you.
Anonymous
  • 14 Answers
  • Posted on Jan 25, 2011
SOURCE: 03 cummins hard start in
DTC P0113 is Intake Air / Charge Temperature Sensor High,
Check wiring to the sensor and if that is good then the sensor may be dirty or bad.
the link below shows what it looks like and has a price for the sensor.
http://www.genosgarage.com/prodinfo.asp?number=4984570
john berens
  • 173 Answers
  • Posted on Aug 20, 2011
SOURCE: turns over won't start getting
GIVE IT A SHOT OF STARTING FLUID IN INTAKE IF IT RUNS FOR A MINUTE THE CONTROLER FOR INJECTIORS HAS PROBLEMS IF NOT CHECK FOR SPARK AT SPARK PLUGS THIS WILL TELL YOU REALLY WHAT SYSTEM YOUR HAVEING PROBLEMS WITH. USALLY IF THERES FUEL AT INJECTORS ITS A SPARK PROBLEM GOOD LUCK
98 Isuzu rodeo, engine cranks and trys to start but it won't
If this is a diesel engine you probably have an air lock in the fuel system. It will need "bleeding" before it will start. If you have already tried bleeding the fuel system there may be an air lock in the injectors. If it still doesn't start I suggest you carry out a compression check because diesel engines need to be in good condition to start easily, especially in cold weather If it is a petrol engine, there could be problems with engine timing or ignition problems.
1helpful
03 dodge ram 1500 crew cab 4.7l v8 starts fine when cold but won't start after it is warm
First i would check the crank sensor by looking for rpm's on the tachometer or scan tool if you see any rpm's then crank sensor is good.Then check for leaking injectors and if they are not leaking then you will need to check the ECM it may have failed.
92 cabriolet starter gets hot and won't start for an hour
if it is a problem starter ( over hot starters for proximity to exhausts) is not uncommon
many manufacturers provide a high performance starter as a replacement and that overcomes that problem
it has fewer windings but use heavier wiring and are used for high performance , high compression engines
the other fix is to manufacture a heat shield around the starter to keep the exhaust heat away
if you go the new starter talk with the auto electrician as they may have to get it from the auto electrical wholesaler
you may get it from a speed/ performance shop but I doubt if it come a auto parts shop
1997 dodge cummins at times won't start can happen either hot or cold runs fine when it does start up
My 1997 dodge cummins turn key and solenoid clicks but starter does not move all the time
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
