I had the same problem too. During the transfer of files, i accidentally cancel it and when i restart, the files continue and ask if i want to delete files in the recorder. I click yes and then i realise it only copy folder A and deleted all the files in the other folders. BAH !I had the same problem too. During the transfer of files, i accidentally cancel it and when i restart, the files continue and ask if i want to delete files in the recorder. I click yes and then i realise it only copy folder A and deleted all the files in the other folders. BAH !
AnonymousMar 14, 2014
recover data from damaged olympus vn-7200recover data from damaged olympus vn-7200
You can't post conmments that contain an email address.
YES, it is definitely possible to recover such kind of files deleted from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to a PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. I hope this will help. Best regards!
Then connect your recorder to another PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Good Luck!
When the Digital Wave Player application copies the files to yourcomputer, the default location is under My Documents>Digital WavePlayer>Message. There, you will see FolderA, FolderB, etc. +Recording & Schedule folders.
If the files are not there, use a file recovery application, such as PhotoRec to recover the deleted files.
Chances are there to recover such kind of deleted files from your Olympus recorder.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP.
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
