The dishwasher fills OK, and drains if you reset it. I found someone talk about test mode for Bosch dishwashers here: http://www.fixya.com/support/t9262482-read_about_problems. I followed the instructions, even though it was a different model. Held 2nd+4th buttons and pressed power on. Display said C8, then changed to P0 when I released the buttons. I pressed 2nd+4th buttons again. All leds lit, then went out with leds above 3rd+4th buttons flashing. So I pressed 3rd+4th. It went through some movements. Display now says E1, with leds above 3rd+4th buttons flashing. Can any help me fix this, please? thanks!
SOURCE: Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
SOURCE: Thanks!
it changes it a bit for me as bosch and kitchenaid have quite a different design but they operate on the same principle.
can you supply me with the full model #?
you could have something caught in the drain pump.
SOURCE: I have a Bosch she44c02uc/ 17 dishwasher. I
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
SOURCE: SHE/43M bosch dishwasher fault code C3, P0, not
I have the exact same thing. While P0 is on the display, Regular Wash is lit and Quick Wash is flashing
