Question about Sony Playstation 3 (PS3) Console
Ps3 freezes within 3 mins of gameplay
Gets hot in the back an the game freezes within 5 mins of game play
    Master:
  • Sony Master
  • 376 Answers
Hello, maybe you need the new Game CDKEYS cheap to fix it. Good luck and enjoy your game.
Posted on Jun 14, 2019
  • 24 Answers
Soundsl like a setting problem. A lot of 40 gig units need to have a setting changed. First update your system then go to video settings there find one called BD 1080p 24Hz output (HDMI) set it to OFF. That may fix it it will fix movies that freeze up after about 5 minutes of play.
Posted on Jan 14, 2009
My p3 will not allow me to play games or blu-ray dvd, it just dirty or damage disk
SOURCE:
My ps3 keeps freezing during games
Problem: Your Playstation 3 console is freezing during gameplay. There are usually two problems that would cause your Playstation 3 to freeze during
gameplay. I will start with the most common problem:
1. The Blu Ray Laser is wearing out. This is a common issue among the newer video game consoles. The laser is constantly lighting up to read the discs while you are playing your Playstation 3 whether you are playing games, Blu Ray movies, or DVD movies. Eventually the laser will burn out. As it starts to wear out, first the games or movies will freeze. After a while, it will not read Blu Ray at all. Finally it will quit reading anything. You can find lasers at the following website starting at $49.95. The same website also performs repairs of the Playstation 3 console:
http://store.richspsxparts.com/pl3paac.html
2. Overheating. This is less common. If your PS3 freezes and you shut it off and back on and it comes on ok, it's probably not overheating. If heat is the problem, it will freeze right away if you turn it back on right away without giving it time to cool off. If it turns on OK with no problem and doesn't immediately freeze up, the laser is your issue. If you turn it back on and it freezes right away, your PS3 may be overheating.
If your PS3 is overheating, the best thing to do is to make sure you do not keep it in an enclosed area. Playstation 3 systems and XBox 360 systems run very hot. You must keep it in the open so it gets as much cool air as possible! You can also upgrade the fan inside of your Playstation 3 with the Whisper Fan which increases cooling. You can also find it at the following website:
http://store.richspsxparts.com/newpl3ps3taw.html
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
My ps3 is freezing 10 min or so into online, and its getting hot
Freezing means the laser is bad and will need to be replaced in order to fix this problem. You can have this done at any professional game console repair company. If you want, you can check us out at www.wiredextreme.com. You can also contact us at support@wiredextreme.com or 214-222-5788. Hope this helps.
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
5 min into a game and the sounds goes then freezes
plugged in ps3 says the hard disc data base will be rebuilt gets to 97 % then goes off ???
Dec 25, 2009 | Sony Playstation 3 (PS3) Console
PS3 freezes but sound still works
when it happens, give it some time, like 5-10 min. the ps3 is most likely accessing the hard drive, and if it is, shutting down in the middle of it could currupt your hdd. if it doesnt work, even after 10 min, call sony tech support, but if it works fine afterwords, i dont see why it would be neccessary. unless it gets worse, i think you should just turn it on, turn it off after a few min, then back on, and then play.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
Game freezing, brand new system
if is new yes call sony and tell them what is going on and they will send you a box with a prepaid label for you to ship the ps3 and they will send you a replacement unit what is happening is that the laser is getting bad I sell new lasers for this unit but if is under warranty then send it to sony
May 13, 2009 | Sony PlayStation® 3 (80GB) Console
Ps3 shuts off during gameplay
My PS3 shuts off 15 minutes after I play can I fix the problem in system settings
Mar 25, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 Freezes after 20 mins of gameplay
PS3 is one of the most amazing gaming device but like other competitorgaming devices (Xbox and Wii) It also has some problems like Freezingup. You may check out the informative Article at ezinearticles. Remedy for PS3 Freezing up.
Jan 15, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is freezing
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up.You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Dec 14, 2008 | Sony Playstation 3 (PS3) Console
My ps3 after in hour of playing freezes and won't play
This is a common problem that can be one or two reasons. One is that your PS3 is overheating during gameplay and is shutting down or freezing. If this is the case you should make sure your ps3 is clean of dust and is in a well insulated area. Try investing in an external fan that will keep your system cool during gameplay.
Secondly you may have a problem with the laser reader. If this is the case you will need to have it repaired by sony. You may be covered under a warranty, so please contact sony to find out your options.
You can contact sony by calling the number listed on the back of almost all of your video game booklets.
Happy Gaming and Good luck to you.
Oct 17, 2008 | Sony Playstation 3 (PS3) Console
PS3 freezing during gameplay
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Jul 15, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
184 people viewed this question
Top Sony Video Game Consoles & Games Experts
shevantha perera
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
