Lost manuel want to down load from internet 0n my remote 6711R1N192A
SOURCE: LG HDD/DVD Recorder Model: RH265
What you need to do is to put in your dvd that you wish to copy onto and then press the DVD button on your remote control. (this is next to the HDD button which is under the POWER button) Then follow the on screen prompts and instructions in the owners manual. I had the same problem but found the solution by mistake!
Hope this helps,
Nicky
SOURCE: Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
SOURCE: My LG, HDD/DVD recorder Model DBRH1979 cannot read
using a dvd/cd cleaner, clean the optical lens of the unit, it could be some dirt that make the player not to read every cd you inserted.
SOURCE: 2 lg dvd players in same room,can I change remote frequency
I have new Panasonic DVD & Combo units stacked on top of each other and had the same problem, until last resort I read the manual and and easily changed the frequency on the DVD unit and remote, you can have up to 3 Panasonic units with different frequencys close to each other.
SOURCE: LG RH266 DVD/HDD RECORDER
hi,i have an lg 389h dvd recorder,it just says hello scrolling across the display,and doesnt respond to any functions on the,remote control,any ideas,cheers.
