- have alternated ram - have switched graphics card - have changed LCD screen - have changed screen cable - have changed screen inverter board - have tried various combinations of the above - have updated bios - have re-flowed motherboard - and tried combination of the above - consistently boots works on external monitor screen powers but remains black, no display.
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode, if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness. Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over. Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop. Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
SOURCE: Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
Hopefully you can find something helpful on this site. Basically you need to flash or reset your bios now. this site also has some links to remove upgrades. LIke i said i hope this helps.
http://www.user-guides.co.uk/Dell/DellManuals/Dell.asp?keywords=Dell+Vostro+Manual&recor=1
SOURCE: LCD flashes and flickers, partial display of bootup and then black screen
Try the following:
Sometimes when you press and hold the corners of the LCD area (not on the LCD itself, but on the frame), and see if it gives you a picture (or at least flickers when you do so).
My opinion is that your LCD could need rewiring or replacing.
SOURCE: lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
SOURCE: Dell Latitude d620 display problem
Sounds like your computer has just bit the dust, do your self a favor and purchase a new one. This time buy an XP, it might be a little bit more, but you get what you pay for.
`Nbryson
SOURCE: laptop inverter problem
you have major problem here - the power regulator on the motherboard which regulates the line voltage down to 12V to feed the inverter, and battery voltage /up/ to 12V to do the same, is blown. I've seen this happen in HP laptops - line voltage to the inverter on mains power reads at 18.2-18.5V (which overloads the inverter), on battery it reads 10.5-11 (which won't fire the inverter). This is usually a sign of a bigger problem. Usually one that involves replacing the motherboard.
