For the past few weeks I have been able to download programmes from BBC IPlayer for the desktop iplayer. Have deleted and reinstalled all related programmes several times, but when reinstalling Expatshield it tells me that I need to install an additional HSS driver, in a separate box, and then when I click to OK it does nothing, and does not advance the Expatshield download. I am able to download for mediaplayer, but have lost the functions that make IPlayer special.
You could run the chkdsk utility. Cick start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility Cick start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors then select check now start should schedule this task when restart it will only schedule on restart if its the Primary hard drive with an operating system on it do not do anything while the chkdsk utility is in progress any input may damage your operating system and your computer. Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps: Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow. Type the following command, and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
SOURCE: Love expat shield. BBC iplayer
Hi there !
You need to upgrade the flash player you are using because the website does not recognized it anymore or it needs higher version of flash player installed in your computer. I have same problem this before and it works.
I am sure it will solve your problem.
SOURCE: Why does expat shield no longer work in order to
Usually what has happened is that the Beeb blocks the ip#'s that anchor uses. Anchor then does a change and it shows up as ip#'s outside of that range and it works again. Until the next time.
I think the longest I have had anchor down was a bit over two weeks. Usually it is off for a day or so every few weeks. Just keep trying Anchor is are pretty good at getting it working again quickly.
Testimonial: "Thank you. I hope so. It is the only cultural satisfaction I get ;)"
SOURCE: I cant't get bbc iplayer
I am having the same problem,same error message. I only get the message when trying to view live TV using the iPlayer. The BBC News channel plays live OK through the BBC News website. Live sport broadcasts play OK though the BBC Sport website. I uninstalled Flash Player and then reinstalled. It made no difference. Please help.
