Cell Phones Logo
Posted on Dec 13, 2012
Zte x500 need unlock code? - ZTE Cell Phones
Anonymous
Level 1:
New Friend:
  • Contributor 44 Answers
  • Posted on Jan 27, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
44
Questions
0
Helped
39975
Points
60
Go to Menu-Settings-LOCATION & SECURITY-Set up screen lock to set the
unlock pattern. If the unlock pattern is entered incorrectly 5 times in a row, the handset will give you a hint to unlock by entering g-mail account, or continue to enter the unlock pattern after 30 seconds. There will be no trouble as long as you remember your unlock pattern. If users didn't bundle with the g-mail account when using Google handset for the first time, then they can't also use g-mail account to unlock after they forget the unlock pattern. The only way is to refresh, however, you should be cautious that this might cause your user data loss.
5 Related Answers
Anonymous
  • Posted on Sep 13, 2009
SOURCE: Unlock Orange ZTE-G X760
how to unlock ZTE X760
Anonymous
  • 132 Answers
  • Posted on Mar 16, 2009
SOURCE: i forgot my code that unlocks my metro pcs zte phone
You can try all zero's (Example: 000000, 0000). Now since your device already has a custom unlock code, more than likely you will need a customer service representative of MetroPcs to assist you, where such information can be accessed.
Anonymous
  • 285 Answers
  • Posted on Mar 03, 2012
SOURCE: screen unlock code for a cricket ZTE X500
format ur phone memory
Anonymous
  • 3422 Answers
  • Posted on Feb 24, 2008
SOURCE: Network unlocking
The best thing is to go HERE and get it unlocked.
Goodluck..
Anonymous
  • 5 Answers
  • Posted on Mar 28, 2010
SOURCE: unlock code for zte f102
this phone cannot yet be unlocked by IMEI only physical unlock only.
We are UK based if you want it unlocking, we have a listing on Ebay.co.uk at the moment.
If you want bulk unlocks, we will do you a good price. Any price is good I suppose as we are the only ones in the UK that can unlock this phone!
Regards,
Grumpy Greyhound
Transfer my phone number to new phone
If the phone still turns on, transfer all your contacts to us SD card and use the same SD card on ur new phone.
Forgot my lock code
If you have forgotten the password to unlock X500,you need to reset the phone also it will erase all the user personal information. First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.When display "ZTE", press the Menu key at the bottom of the screen;Choose "Wipe data/factory reset" through volume key Press "Camera" key to confirm the above item Choose "YES...delete all user data" Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Mar 18, 2013 • ZTE Score
Unroot my cricket wireless zte x500
The service provider will know it better.contact cricket
6helpful
ZTE-X500 USB DRIVERS
There is no need of USB drivers for this device. If the phone uses SD card function, directly connect the phone to the PC through the data cable. As "USB connected" appears at the top of LCD, use your fingers to pull down the top, tap "USB connection" and then select "Mount USB".
2answers
Zte x500 factory reset
Default 4 Digit user code: 1234,1122 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Zte x500 reset code
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Sep 24, 2012 • Cell Phones
My Cicket Zte X500 wont power on
new battery is usually what you have to do get the phone to work again.
2answers
Need to unlock my metro zte phone
should be the last 4 digits of your phone number.
6helpful
2answers
3helpful
2answers
Mobile unlocking
im blocked out of my zte x500 cricket phoen and the only way i can dile out is if its an emergency call, if there a code that i can put in that will unlock it
Dec 22, 2011 • Cell Phones
Top ZTE Cell Phones Experts
vince
nexrad_chris
Paul Carew
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
