I have a xo vision xod1740bt. showing a car- on screen. trying to hook up back sight camera. i hook up the orange wire to power. its supose to be the control line for the camera. some reason it stays on all the time when i hook it up to power. how do i hook the wires up from the stero xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
If you have any problem related to the backup of your camera vision then, I would like to suggest you prefer Car Backup Camera online service. They can fix all the minor or major issues at an affordable cost. They also provide the best quality of Camera if you want to replace your old camera then this online service is the best option to buy a camera.
I am having the same problem. For testing purpose I have the pos/neg from the camera to the pos/neg on the battery. The camera video out is to the XO1935 video in but I get nothing. I tried touching the reverse wire to a pos just to see if it made a difference, still nothing. any ideas?
Hello!
i m buying from Chinavasion Car Rear View Camera
with Wide Angle Lens + Up/Down Adjustment model [CVSH-CS25] and 1-DIN
GPS Media Player with 7 Inch Touch Screen and DVB-T model CVHA-C21. And
i need help with connection Car Rear View Camera with Wide Angle Lens
GPS Car DVD with DVB-T and Bluetooth (1-DIN).
I have a problem with the reverse camera.I compiled all the
instructions that came with the dvd and camera excluded orange wire.At
this writing wire camera but not written with as soon as the drafts.
Camera in the aux mode does not work.Does the camera work in some other
fashion? If it works in a different mode,how to run it? I need some
detailed instructions for connecting the camera and dvid player. Camera
works with other LCD monitor.When you connect to aux input on the front
starani dvd player and camera to reproduce an image. When you connect
with the entrance on the back starani dvd player parking provided for
the camera, the camera does not work and can not reproduce the image.
The instructions that came with the dvd player does not write anything
about connecting the camera or how to reverse in its settings menu
naparaviti play reverse image camera with DVD player.
Please for help !!!!
I have an XO Vision 1735 and I hooked up a back up camera. I power it off of my reverse light wires. But, the problem I am having is that the camera doesn't work when hooked up to the back up camera input on the stereo. Right now I have it plugged into the aux. input and it works, but it has to be in aux. mode. My question is, should the back up camera come on when put in reverse when the stereo is in any mode ex. (radio)? And why does it not work when plugged into the camera input? To the question above, try powering the camera off of your reverse light wires. And I also wired the pink wire to ground which will allow your passengers to view DVD's without being in park. Hope this helps.
