Transfer stall USB bitmap data. Either the USB board is flaky or the Spider PBA is faulty. Before replacing anything, upgrade the software and firmware to the latest level. The new software may solve the errors.
This article is about two printer error codes, 22551 and 22531. These codes are associated with the OCE Plotwave 345 printer. The error code 22551 means that the printer has lost its connection to the computer, and the error code 22531 means that there is a communication problem between the printer and the computer.
this error more related to software problem,but you need do below step to check their hardware is in good condition.if all ok no problem,you may need to reformat their OS
1.off machine/on machine
2.pls check their controller connection (in you left side back cover down area).Make sure all the port are plug in properties and also in correct location,you cannot plug in to anywhere if no you will get the error code.
3. open fusing door ,try to unlock screw on right side back cover got 3 screw (torx 15 or 20)
4.open that cover look down that area got 1 big spider board.make sure all their connector usb port are plug in properties and in correct location.
5. check the big board should be got 3 LED green light stable on if no use machine.no got red LED on.
6.check that small board are properties install in good position in big board location.
7.check that small board must go 1 LED green light always falshing or stable,if got Red LED light on means this board faulty need replace new unit.
Please verify the error code if this is a PlotWave 300. If this is a ColorWave 300, then the error is Present sensor 2 roll 2 does not open during retract. Check to see if the sensor is blocked or broken. at the input side of the lower roll.
Fuser Temperature Protection Circuit Failed. Turn off the printer completely. Power off in front, and turn off main power at right, rear, bottom and unplug from the wall. Open up the fuser and take off the right hand cover. This is High Voltage. If you are uncomfortable with risking your health, do not proceed further. You will see 4 connectors (black, usually but with red insulators) that plug into the right hand side of the fuser. Unplug them and check the connectors as well as test if they are seated correctly. Ensure the red insulating jackets are pushed toward the connectors. IF everything looks OK, and the printer still exhibits this error code you will have to call an authorized Oce service technician.
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
Error 08130 Fuser temperature protection circuit failed. This could be the Spider PBA or it could be the connections to the fuser itself.
Best to call an authorized service rep.
JAI UN PROBLEME AU PLOTWAVE 300 MARQUE OCE
CODE ERREUR 8510
C QUOI LE PROBLEME ET C DU A QUOI ET QUESQUE JE DOIT CHANGER
MERCI
REPONDEZ PAR EMAIL [email protected]
