Computers & Internet Logo
MIGUEL ACEVES Posted on Dec 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FORMATEAR MICRO SD HC 8GB
NO PUEDO FORMATEAR MICRO SD HC EN MI LAPTOP
max carson
Level 3:
  • Toshiba Master 7,627 Answers
  • Posted on Dec 13, 2012
max carson
Toshiba Master
Level 3:
Answers
7627
Questions
Helped
1013653
Points
21773
Depending on your laptop, 8 GB SD cards may not work. That said, insert the SD card, open Computer, right click on the SD Card icon, format.
5 Related Answers
Jerry Umali
  • 979 Answers
  • Posted on Oct 05, 2009
SOURCE: my acer 3680 laptop wo't read a 4 gig hc sd card
Good day sir/maam, you may need a driver for your SD card reader for vista. pop in the cd that came with your notebook to the cd drive. make sure its for Vista.
If still does not work, plug in a non HC sd, like a 1 gig SD card. if it works, then the card reader only supports non hc SD. ( I know it usually supports HC cards ) check also for viruses. there are viruses that can dissable sd card readers. just make sure your laptop is virus free.
guidoromero
Grupo Tecnológico en Línea
  • 301 Answers
  • Posted on Aug 01, 2010
SOURCE: formatear mi laptop Dell inspiron
guarda tu informacion primero, luego introduce el cd o dvd de winodws , reinicia tu maquina , cuando la secuecia de booteo reconoce la unidad de cd/dvd aparece una leyenda que dice presionar tecla para continuar y lo haces , luego sigue los pasos q aparecen ahi
Anonymous
  • 2296 Answers
  • Posted on Jan 03, 2011
SOURCE: necesito formatear mi maquina es
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Anonymous
  • 145 Answers
  • Posted on Jan 19, 2011
SOURCE: My Pavillion dv 1000 wont
If its above 2 gb most older laptops won't because the card is in FAT and not FAT 32. cards 4 gb and over are written differently you can hook your camera up to your computer and transfer then that way or purchase a HCSD card reader for higher capacity cards.
Anonymous
  • 72 Answers
  • Posted on Mar 31, 2011
SOURCE: no puedo entrar en mi
Hola, este sitio web ayudar? a recuperar tu cuenta
https://www.facebook.com/help/?page=174&hloc=es_LA
Espero que esto ayude!
Como puedo conectar mi dvr al internet para ver las camaras desde mi celular
Hola Juan Lugo, existen diferentes Software y aplicaciones que podemos utilizar para lograr este proposito, seria mas facil si nos brindas mas informacion, ya que depende del tipo de camara y sus caracteristicas, por ejemplo yo estoy usando Wize camara que no necesito un DVR ya que solamente con insertar una micro SDHC ( una memoria de celular) ella graba constatemente si lo deseo y puedo ver en mi celular en tiempo real lo mismo las grabaciones como en tiempo real lo que esta emitiendo; pero bueno voy a dejarte un video que no es hecho por mi, pero puede ayudarte a lograr el objetivo, le deseo buena suerte.
Micro sd hc password remove
format it useing nokia 6220 and c5-00 100% working
En el pa korg 500 de error aparece os lectura de archivos Que Se Puede HACER
Carlos Hi
despues de formatear el equipo todo tiene que volver como recibistes el pa 500 nuevo de fabrica
Necesito formatear mi maquina es una laptop averatec 3200 solo que cuando quiero entrar al bios tiene password y no puedo quitarlo
1helpful
He probado todas las paginas habidas y por haber......sic..... y no puedo encontrar la manera d liberar mi nokia 6555 imei: 356984012437906 me puedes ayudar?? bsote!
no hay soporte código maestro en s40 móvil tiene que el flash de su móvil intenta formatear con Phoenix aquí es el tutorial para formatear el nokia s40 móviles
When i plug in my 8gb micro sd card my pc doesnt reconise it
is this a SDHC or some other type of high speed card ?
Does your SD reader accepts HC model ?
Have you tried a another SD Card ?
Regards
GeWiz.
3helpful
2answers
I have a 4gb micro sd card and it says that it only has a total of 146k of space on the disk. It won't let me copy anything on it. And i haven't placed anything on it-so i don't know why its out of space.
Is it a 4Gb micro sdHC? The 4 GB and above are all HC (High Capacity), and can only be read by HC reading devices. If you can see them at all, they will report some foolish size which yours is doing. They use a different protocal so they can not be read by a reader which is not HC. So what you need to do is get a HC capable reader.
8gb sandisk micro sd hc for samsung pixon not recognised by phone
i have come to the conclusion the mgb card itself is corrupted
i put in my nokia 5800 and it says card corrupted
i format card all looks ok
remove from nokia
and put back in again
and card corrupted again,
also 8gb card from my nokia (not the same one)
works in the pixion ok
so im sending back the card
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
