How do i adjusts my clutch cable 97 dyne super glide
To properly adjust the clutch, you must adjust not only the cable but the clutch as well.
Follow the cable down to the front down tubes of the frame. There you should see a rubber bellows. Slide the bellows up or down to allow you to get to the adjustment. Loosen the lock nut and adjust the cable as short as possible.
Now, remove the derby cover from your primary. In the center of the clutch assembly you'll see a screw that takes a hex key or allen wrench. Loosen the lock nut. Turn the screw inwards until it meets a resistance. Do this several times if necessary to get the feel of what you're doing. You want to go to you just feel resistance, not far enough to start releasing the clutch. Once you feel the resistance, back the screw out 1/2 to 1 full turn. Lock the locknut down and replace the derby cover.
At the cable, adjust the cable back out until you get about 1/8" (3mm) freeplay at the lever. I usually just set the freeplay at the adjuster. If you'll grab the upper part of the cable and pull, it will come out of the adjuster. Set this distance to 1/8". When finished, if you just take the slack out of the cable with the lever, don't pull it, just take the slack out, you'll have about the thickness of a nickle between the lever and the lever mount.
Good Luck, Steve
That was it
Thanks
