all other burners work well. Creda model # ggh 182 no. 42407
serial # 11 100137
left front burner sparks but does not light.
I have a Creda GGH102 gas stovetop with electric gizmos that spark - and click - but rarely do what they are supposed to do an light the stove!
I have cleaned the holes in the circular covers and the little sparking metal doodads to no avail. (Cleaning the holes makes the stove burn better when I finally break down and start i - with a match!)
You can't post conmments that contain an email address.
I've had this happen before,first make sure that the black burner cap is clean underneath and it's making good contact with the aluminium burner,also make sure the igniter is sparking across to the burner, check the ceramic coating around the igniter isn't cracked or the wires shorting out . Good luck.
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Clean the gas nozzle w/small wire are located at the back of the gas cook top /shut off the gas clean small gas nozzle clog / w moisture /rust dust and any foreing material.
left front burner sparks but doesn't light
creda gas 5 burner cook top front left burner sparks but does not light
serial # 11 100137
