The clothes are wet after spinning
When the clothes are wet at the end of a cycle, check these:
Motor couplerSpin cycleSiphoningWater-inlet valveEl Resorte de la trasmision en inges se llama MOTOR COUPLER
Si pincha aqui y pone correctamente su numero de modelo pede veer directamente los diagramas para instalar el motor coupler.
Si no enacuentra numero de modelo mire:
help finding the model number on your appliance?
Aqui siguen en dettalle mas possibiles rasones por su problema (en ingles)
Motor coupler
To
test the motor coupler, re-start the washer in its spin cycle. Let the
machine run for a minute, and then open the lid and notice whether the
tub is spinning:
- If it's spinning when you lift the lid, the coupler is fine.
- If
it isn't spinning--and your machine was produced by Whirlpool®--you may
have a broken coupler. Many Whirlpool-made washers use a small,
relatively inexpensive device called a motor coupling. This
plastic-and-rubber component is mounted to the shaft of the motor on
one side, and to the transmission on the other. Over time, the coupler
wears out and fails. When that happens, you need to replace it
completely.
Spin cycle
If
the washer doesn't reach its proper spin speed, the clothes may be too
wet at the end of a cycle. Check to be sure the load is properly
balanced and run a spin cycle again. If the clothes are still wet, you
may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),
or a worn motor pulley or tub bearing. Replace the applicable
component.
Alternatively, there could be clothes caught
between the inner and outer tubs. Read the "It spins but won't pump"
section of the "It won't drain" section. Also, there could be other
things that cause friction on the drive train. Seek the assistance of a
qualified appliance repair technician.
Siphoning
If
the water that pumps from the machine goes right back into the machine
after the spin cycle, it may be because your washer is siphoning the
water from a laundry tub with a slow drain, back into the washer. Try
to improve the draining of the laundry tub. (Is there something stuck
in the drain?) Also, be sure the drain hose doesn't reach more than
about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet
valves eventually fail. One problem that may develop with a water-inlet
valve is that it can no longer completely shut off when the electricity
is turned off to it. Then, the valve may leak and drip water into the
clothes tub--you may notice that your washer has water in it when you
haven't used it for a few days. To fix this, replace the valve.
Aconsejo tambien comprar el manual de servicio aquiAqui hay un ejemplo de ingranages for el motor coupler, se montan en el palito donde el motore enchufa con los otros ingranajes:
Agradeceria si pede votar la solucion, posibilmente en azul.
Muchas gracias.
Spins slowly when full during spin cycle. When its empty it spins fine, but when there is the weight of a full load it is very slow. i can stop the barrel using my hand with no problem.
My new Maytag top loader performs well in every cycle except the spin cycle. Leaves clothes dripping and have checked the vent and drain. No plugs there. Pump seems to pump well as it drains like gangbusters in the beginning of the spin cycle and doesn't spin them out. Also spins so slow that the fabric softener ends up on the clothes and stains them. I now have to add it myself; can't use the dispenser and respin the clothes to get them spun out enough to put in the dryer. The problem began early on and one repairman said they don't spin out as well as other machines so I didn't report it and now my maintainance has expired. Any help would be greatly appreciated.
same problem, spins noticeable slower, and clothes are dripping wet after cycle
I have a Maytag Performa. All the cycles work great excellent the spin cycle. Water is being pumped out but it is not spinning with get the rest of the water and soap out of the clothes. Is there a solution
My Admiral model AL44000 works fine until it gets to the spin cycle.The machine won't rinse the cloths leaving them wet when the cycle is completed.I've stuck a screwdriver in the lid switch and it seems that the agitator is trying to turn but can be stopped with little to no pressure by hand.This model dosen't seem to have any belts that may be slipping .any advise.
clothes very wet after spin cycle
my washerstarted washing a load of clothes yesterday but got to the spin cycle and stopped. Idiscovered a sock is missing. Where could the sock be lodged at?
Washer works as should, except when last spin, clothes are still able to be hand rung.
during spin cycle wet clothes get out uneven, I have a very hard time getting the lid lock to release, very frustrating!
