how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER915B403001
Lamp (180W)
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
When tv and ps3 backswitch turned on hold down the front power button
when off until the ps3 has done a double beep after the intitial beep
and wait for a max of 1 min and initial set up screen should appear
The lamp can cause the picture to cycle without spitting out a lamp error. I'd replace the lamp and clean out the dust/dirt from fans, etc to hopefully resolve your issues.
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance: 1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours 2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris. 3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
the lamp was replaced 5 days ago?
I can't get to the lamp in my pt-50lc13
