The ethernet driver had been installed successfully but it did't work. I switch the cable and start the google chrome but the home page doesn't loading in. I checked the network connection and it works, There is sent and received data but the packages number is low. but the wireless network is working well. How can i solve my problem? Thanks!
Did you reboot the machine? Did you reboot the wireless device? Try this procedure: http://compnetworking.about.com/cs/windowsnetworkin1/ht/renewipaddrwxp.htm
SOURCE: IBM Lenovo T60 connection to Samsumg 50'' TV using CGA cable
Try just pressing "Fn" and "F7" keys until the output switches to your TV.
SOURCE: Problems to configue network controller in IBM T42
There are several different LAN, wireless, & modem devices that are installed on the T40 series laptops. For example, if one of the network driver or modem driver doesn't work then install a different one. Make sure you download all the various device drivers for your model laptop and the XP version of those driver.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP device drivers for your model laptop,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
SOURCE: Lenovo WinXP - Ethernet port issue
Hi. Try to check the steps as give below.
Steps from 1-3 is for checking physical connectivity of the ethernet port and the last step is for checking OS issue. If network card do not work with Live OS as well, you can directly come to conclusion that its ethernet card that is not working properly and you need to get is repaired.
Cheers!
Testimonial: "I'll give it a try, and Thank you for all your help. I will keep you informed if any issues arise. Sincerely YnotPhone"
