Dell Inspiron 6000 Notebook Logo
Posted on Jan 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Directions to replace the display for a Inspriorn 6000
I have a new display just need to install it
Anonymous
Level 2:
Sergeant:
  • Expert 366 Answers
  • Posted on Jan 13, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
366
Questions
0
Helped
125939
Points
831
Walter H Boehm
Level 3:
  • Dell Master 998 Answers
Walter H Boehm
Dell Master
Level 3:
Answers
998
Questions
0
Helped
340987
Points
2289
Here's a link to Inspiron 6000 service manual: http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Display screen is cracked
how can I get a new replcement screen for my cobra 6000 pro hd 5 navigation. can u give some advice on how I can get a replacement screen
1helpful
I need a manual in English for my Nemox Pro Gelato 6000 ice cream
You must register your product and request a new manual in english directly from them. You can do that directly at their site.
http://www.nemox.com/uk/dillers.html
2answers
How do I install a replacement keyboard for my Dell Inspiron 6000 laptop?
Hi friend,
You need to open you keyboard then open your keyboard power lied from *********** board then put new power lied then close your keyboard. then restart your laptops
My display is EXTREMELY faint
Run PSA Diagnostics by using FN + Power Button
Download and Install the Latest BIOS for Your Computer
Cannot get Printer reinstalled after having Hard Drive replaced.
first you need to installed the sytem driver like mothrboard driver and the display driver then start installing the printer driver if you dont have printer driver you can download from this link,
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1153494&
Dell 6000 laptop screen blanks out - bought new screen
ManualsBack to Contents Page
Display Assembly and Display LatchDell Inspiron™ 6000 Service Manual
Display Assembly
Display Bezel
Display Panel
Display Latch
Display AssemblyRemoving the Display AssemblyCAUTION: Before you perform the following procedures, see the safety instructions in the Product Information Guide.NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as the back panel) on the computer.NOTICE: To avoid damaging the system board, you must remove the main battery before you begin working inside the computer.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
  2. Remove the hinge cover.
  3. Remove the keyboard.
  4. Open the display all the way (180 degrees) so that it lies flat against your work surface.
  5. Remove the four M2.5 x 5-mm screws (two on each side) that connect the display assembly to the computer.
  6. Loosen the screw that connects the grounding wire to the system board.
  7. Use the pull-tab to disconnect the display cable from the system board.
  8. If a wireless Mini PCI card is installed, disconnect the antenna cables from the card.
  9. Lift the display assembly from the computer.
Boot up
You need to replace that display screen.
1helpful
2answers
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
2helpful
2answers
Cannon ir 6000 ver 8
my copier show error for E601.Than i am change hard disk.now display only download mode.i want ir 6000 version 8 flash software. please help me....
1helpful
2answers
DISPLAY CALL SERVICE ERROR 6000:0023457 in the LCD of FS 3900
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Good Luck!!!
please do rateing .....
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
