Samsung RS2630SH Side by Side Refrigerator Logo
Ian Hughes Posted on Jun 11, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rs21dcns the ice-tray does not fill with water to make ice-cubes, although water is being dispensed through water dispenser no problem. Is there a pump or valve to let water into the tray once the tray has been emptied? The motor to empty the ice-cube tray still works ok.
  • 8 more comments
  • Ian Hughes Jun 12, 2007
    posted the above question, still waiting and hoping for a helpful solution, please help.
  • Anonymous Mar 12, 2014
    quit makin ice, no water flow or motor action
  • Anonymous Mar 14, 2014
    why is water not dispensing?
  • Anonymous Mar 15, 2014
    no water is being sent to the ice cube tray
  • Anonymous Mar 16, 2014
    ice cube tray is stuck
    ice cube tray does not turn back after empying
    ice cube tray empty and never turned back to fill
  • Anonymous Mar 17, 2014
    no water in ice cube tray
  • Anonymous Mar 20, 2014
    water pump makes working noise but no water fills tray
  • Anonymous Mar 29, 2014
    Fill valve: where is it? Making a loud, horrible groaning noise when either icemaker fills or water is dispensed
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Jun 13, 2007
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898186
Points
3964
There is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Why are the cubes not breaking apart when dumping from the tray?
It is over-filling and the cubes are fused together... If the fill is adjustable, lower it, but you may need a new water valve... Frigidaire Water Inlet Valve 242252702
Ice cubes wont come out when the dispenser tips it upside down
The ice mold tray has built up deposits that "glue" the ice cubes to the tray. This usually means you will have to change the mold tray. You could try vinegar or lemon juice to clean it but the trays are not that expensive.
2helpful
My Bosch ice maker has a problem. It has frozen over and does not dispense the ice cubes, the refrigerator thinks it has dispensed the cubes and so try's to fill the ice cube tray up again with wa
Ice makers have heaters that loosen the cubes when time for harvest. Sounds like the heater on yours is bad, or maybe the ice maker itself is just bad. Most likely will have to replace ice maker.
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
2helpful
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Problems with ice maker
Bsbbj,
If the cubes are fusing together (such as when you overfill an ice tray), your solution could be as simple as adjusting the fill volume (there should be an adjustment under the front plastic cover, and the cover should just pop off and snap back on unless you see screws attaching it) and when your ice maker was replaced this probably wasn't calibrated correctly. Your mention of the side of the maker bulging also leads me to believe the water is overflowing and freezing within the dispenser (causing it to bulge and not dispense).
I hope this helps and Good luck.
2answers
Ice dispenser jamming
There is a revised bucket that's made to prevent that.
If your refrig has a steel liner order WR17X11308
If it has a plastic liner order WR17X11315
3helpful
4answers
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
