Plug lg 3d blu ray home theather model# lhb336. it shows on the screen boot. press on it shows please wait.
Check working condition hardware. May be malfunction Main Boar or AMP. Unplug cable (wires) attached from Power PCB Board and main board to AMP PCB Board. Turn ON, if again comes message " Please wait" and unit sot down itself- Malfunction main board. If unit booted UP -OK -replace AMP board. Parts are available on our web
SOURCE: I can't get the sound to bypass the tv's speakers
Are you hooking the TV to the Blu-Ray HTS with the HDMI cable¿ I have a client that had the HDMI cable from the HTS to the TV and needed to purchase an "Optical Cable" to get the sound from the TV to the HTS when they were using the cable box as the input. I hope this helps you going into the right direction.
SOURCE: LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
SOURCE: how can i update my LG LHB 953?
most blu-ray players needed to be updated to play this movie check to see if yours is updateable from the manufactures website
SOURCE: Blu Ray doesn't seem to work correctly
In all reality you are probably not doing anything wrong. You have a great TV and a pretty good BluRay player.
One thing about looking at movies in a store is usually you look at the screen further away than you usually do at home. Also, some of the demo disks they use are recored at a higher bit rate than many movies you can buy. Store displays are designed to show off TV units to make them sell, they do not care about them after you leave the store.
Many people do not know that some Bluray movies can actually look worse than DVD. Avatar for example is encoded at an average of 28 Mpbs on Bluray, and Avatar on DVD is encoded at around 7 Mbps. However, note that a 1080p screen has 6 times as many pixels as DVD, but in this case only 4 times the amount of data for the picture, so in all actuality Bluray has a lower quality picture per pixel than DVD. Some Bluray movies claim that they are 1080p, but are encoded as low as 14 Mbps (They do this so they can fit the movie on a single layer Bluray disk instead of the standard dual layer disks.) Another thing to note is that the color 'black' on Bluray is like 'Bass' on an MP3, in that they both require high bit rates. A low bitrate on Bluray will produce a grainy black picture, and on an MP3 a low bitrate will make the bass sound tinny. A great example of this is the movie 'Crash' which looks way better on DVD than that of Bluray.
From my experience, the best Bluray movies to show off your system are the BBC's 'Natural Earth', and 'Doctor who' like 'Planet of the dead.' Dr who is 1080i, but is encoded at the highest bitrate that I have seen on any Bluray movie so far, and looks outstanding.
Good Luck
SOURCE: I have a LG LHB335 Blu-Ray home theater system,
LG documentation states: When you use SIMPLINK function, you have to connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
I had the same problem with my LG bd670
blu ray. I fixed it. It was a failed firmware update. I went to the
LG website and downloaded the update and copied it onto a flash
drive. I unplugged my blu ray (hdmi cable too), put the flash drive
into the usb port on front, and plugged in the power cord. It took a
couple of minutes but it loaded the update from the flash drive and
shut off. I plugged the in hdmi cable and turned on the blu ray and
done. All was well in the world again. I hope this helps anyone with
the "boot" error message on the LG bd670 blu ray player.
