I turn on my tv and green light is on, but is took 35 muntes to turn on
SOURCE: LG32LC2D - Sound slow to start
This is indicative of a bad main board that will need replaced. For this model make sure the repair person has the full product code (from the back of the unit) so that they can get the correct main board ordered (there are multiple versions depending on the product code). Hope this helps.
SOURCE: LG 47
This means that the bulb is bad, and is taking forever to heat up. You need to get the bulb replaced to fix it.
SOURCE: tv screen goes gray after a few minutes
SOUNDS LIKE MAIN BOARD/BUT IT COULD BE CONTROL BOARD/REPAIR SHOP
SOURCE: TV only works for 5
Nothing you're gonna be able to fix yourself... Sorry but you're gonna have to take it somewhere to fix that particular problem
Please.. I turn on my tv and the screen is black.
did you try the flashlight suggestion in a very dark room or not?
I found on the main board 2 capacitor 1000UF 25 VOLTS and 1 capacitor 3300
3300UF 1o volts,,those capacitors are bad. I changed
and tv turn on and the screen is black
