Janome Memory Craft 9000 Computerized Sewing Machine Logo
Anonymous Posted on Dec 12, 2012
I was embroidering on my janome 9000 it jammed and went dead and won't come back on!
sylviaivie
Level 3:
  • Janome Master 1,564 Answers
  • Posted on Dec 12, 2012
sylviaivie
Janome Master
Level 3:
Answers
1564
Questions
Helped
425823
Points
3583
Be sure that it's still plugged in and not on a plug in that is controlled by a switch that got accidentally turned off.
Other than that it is likely that a fuse got blown or the power supply died. In that case take it in for repair.
5 Related Answers
Anonymous
  • Posted on Oct 17, 2008
SOURCE: janome 9000
Thank you Thank you .....i had taken this machine to a Janome dealer..he said it needed a new computer...i was scepticle wrote in here and guess what..it was a $2.00 fuse!!! see some ppl are just not HONEST!!! Thanks so much!!!
Anonymous
  • 1952 Answers
  • Posted on Aug 26, 2009
SOURCE: sewing/embroidery machine janome mc9700 making
Please be more specific with the clicking noise that you are hearing- when does it make that noise, is the bobbin case in or out, where is it coming from,
Anonymous
  • Posted on Jan 10, 2010
SOURCE: Janome 9000 seems to be jammed.
I had the same problem with my 9000. After my third visit to the repair shop they finally told me to always check my thread uptake lever. I have had no problems since.
Anonymous
  • Posted on Mar 11, 2010
SOURCE: janome 9000 refusing to start
I'll bet it's the fuse. I had the same problem about a year ago.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Mar 29, 2012
SOURCE: Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
My Janome 9000 jammed then lost power and won’t come back on
This is a problem with the A board. If you would like more details on the problem please contact us on [email protected]
Need help using flash stick to download embroidery designs from computer and what they are jef, emb,
.Jef and .Dst will work on a Janome machine. You can buy designs per the hoop sizes for your machine. Buy, download, and transfer received file to a USB drive to transfer deign to machine.
Cheers,
Embroidery Services
San Diego, CA
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
2answers
My janome memory 9000 squeaks when embroidering
If it squeaks when you are embroidering and not when you are sewing, it's the belts on the embroidery unit. From use, they can become glazed, slick and then they squeak.
If it squeaks when you are doing either, it's more than likely an internal lubrication of the machine that needs to be done by a trained technician.
Cheers,
Kelly
Embroidery Services
San Diego, CA
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
I started sewing and my machine just went black and stopped. It won't come back on. There is no sound, no lights, nothing. What can I do?
it's possible that either the computer motherboard went out on it.
since it's a janome computerized sewing machine I would suggest
having it serviced to see what's wrong.
Can a memory craft 9000 embroidery machine embroider hats?
I have seen some clever ways on you- tube to make unusual shapes fit into the hoop, using clips etc. You can also buy sticky stabliser so the hoop holds the items without it being in the hoop. I'm sure you can also get devices to help you embroider hats, but i'm not sure they will fit the 9000. try an internet search for more information and possible devices
4helpful
How large an area will the 9000 embroider?
The embroidery field (or "stitch field") is roughly 4x5 inches (a wee bit less, but roughly that size).
Exactly? 100 mm x 120 mm or 3.93 inches x 4.72 inches.
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
