Question about Olympus Stylus 410 / ? 410 Digital Camera
When i try to charge my battery the red light keeps flashing
My battery has died and when i tried to charge it the charger red light keeps flashing and wont hold any charge in the battery?
    Genius:
  • 2,985 Answers
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Posted on Jun 11, 2007
SOURCE:
When its charging it flashes green & red and won't take a charge
If it is a Makita battery charger it means the battery has died or has an internal fault, or is too hot.
Take it out of the charger, let the battery cool down if required and try again.
If both red and green lights are flashing, try a different battery.
It might be time for a replacement battery.
Mar 21, 2015 | Drills
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
The red light that indicates its charging keeps flashing
How old is the battery? Keep in mind they aren't meant to last for more than a year or two, regardless of how often they're used. Generic replacements are actually inexpensive these days. Here's some from Amazon:
http://www.amazon.com/s/ref=nb_ss_e?url=search-alias%3Delectronics&field-keywords=s880+np-20+battery&x=12&y=22
Jun 06, 2009 | Casio Exilim EX-S880 Digital Camera
Battery won't charge on casio ex-z77 exilim
It's a known Fault with the NP-20 battery don't order one and pay for it, ring or e-mail casio customer service they should send you one out for free!! When you receive the new one don't let it die, make sure and keep it partially charged at all time or the charger won't recognize it. Really casio should recall this battery but for some reason they insist on replacing faulty batteries with more faulty batteries!??!
Mar 26, 2009 | Casio Exilim EX-Z77 Digital Camera
My camera won't turn on. I've tried to charge the battery but th
I've had this happen to me in the past.  It generally means that your charger has died, or your battery's connections need to be cleaned.
Try using a Q-tip and some Windex to clean the contacts on the battery.  Let it charge overnight.
If that doesn't work, and you're still under warranty, contact Casio. They replaced a charger I had a few years back, no hassle.  They know it's an issue, and are pretty quick about replacing the defective one.
If you're not under warranty, a Casio battery charger can be found on eBay for a few dollars.
Mar 18, 2009 | Casio Cameras
Cant charge my battery
i have same camera.. but i dont think this is a problem.. while charging light keep flash.. when it completes charging it shows u solid red light..
Dec 25, 2008 | Nikon Coolpix S550 10 Megapixel Digital...
Battery will not hold a charge.
Casio says:
Red blinking light = defective battery
No flashing light = possible defective charger.
What you can do is send all your stuff into casio and they will test everything for you and see what they could replace for you.
Sep 03, 2007 | Casio Exilim EX-S600 Digital Camera
Olympus Stylus 410 / ? 410 Digital Camera Logo
1,149 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
