Computer HP a530n
Operating System Information
Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
System Device Information
Processor
AMD AMD Athlon(tm) 64 Processor 3200+ 1994.9 Mhz
Memory
System Total
1536.3
Virtual Total
2047.9
Pagefile Total
2153.6
Snapshot
System Available
959.7
Virtual Available
1991.7
Pagefile Available
1618.9
Network Card Information
Name
NVIDIA nForce MCP Networking Controller - Packet Scheduler Miniport
IP Address
Subnet Mask
255.255.255.0
Gateway
192.168.254.254
Primary WINS Server
N/A
DHCP
192.168.254.254
nec 17'' multisync lcd monitor
Hp a530n
SOURCE: touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
SOURCE: Distorted shrunken picture
hi
reduce the resolution to a bit lower and the refresh rate to a nominal 60hz and things should get back to normal
my hunch is u r using a slightly high resolution and refresh rates
but before that try the buttons on the monitor to see if expanding the image sideways or top and bottom would help initially
cheers
pls rate if this was any help
SOURCE: How do you put a monitor into power save?
Depending on your operating system go to Control Panel of Windows and find the Power Options section.
There should be a setting there to change how long to waite before the monitor sleeps.
SOURCE: NEC multiSync 1700V as external monitor for
Hi, if the 17 inch lcd screen is not a widescreen then the problem with the screen is possibly nothing more than the aspect ratio or resolution, which ever way you wanna look at it. All laptops have a widescreen type of ratio, so you will have to be either willing to change the resolution when you switch screens or setup different profiles, which you should beable to do through control panel, appearance and then personalization, you will then have access to it.
SOURCE: My monitor (nec multisync lcd
See my tip here: http://www.fixya.com/support/r6836567-lcd_monitor_displays_background_fine
Testimonial: "Thank you"
