I have 4gb memory card, i have taken lot of videos n pictures, it will shows on camera.. but when i was trying to take this videos n photos from pc using card reader it shows empty.. but the properties shows its 3.25gb full n 300mb free memory... i want this pictures n videos.. its to much important for me.. what to do... please kindly help me.. :(
You need to change a new card, maybe the card is damaged or broken.
By the way, if you want to enhance the photo quality, make use of Leawo Photo Enhancer. This software is able to automatically improve quality of the photos you have taken due to its Artificial Intelligence Enhancer Technology.
The card has corrupted. You'll likely need to use recovery software (see this article). After recovery, youmay need to format the card in your camera to correct the corruption.
SOURCE: Cannot remove memory card write protection Nikon Coolpixs9
Take your memory card out and look to see if you may have moved the sliding switch on the memory card, if you have move it back.
SOURCE: problem with importing images to laptop(macbook) from nikond200 trough data cable
Camera must be in point-to-point USB mode for remote tethering to work.
In menu with wrench icon, make sure USB is set to "P" point-to-point.
SOURCE: Nikon Coolpix 5600 can't upload to PC
I need to know the log appearing before I can assist. Many issues can cause cameras not to upload. Is this a sudden problem, ie, have you uploaded before successfully to your pc? Pc issues will also stop you. Let's do this step by step ans start with the log thta appears. Let me know.
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
SOURCE: Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
