SOURCE: my printer canon pixma mp 240 shows the error P7
Your waste ink absorber is full and I am yet to find instructions on how to reset the counter.
SOURCE: Error Code B200 on Canon Pixma IP4300
Just restart the system and turn off the printer and turn on the printer it will work.
Check did you correctly placed your cartidges.
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
SOURCE: my printer canon pixma mp258
Indicator appears blinking lights on the printer " P,O, 8′. That Mean The print head temperature above the specified value. You can replace the ink cartridge or refill the cartridge. Step to resolv this error Step 1 : Turn Off Printer Step 2 : Remove Cartridge Step 3 : Refilling the cartridge Step 4 : Reinstall the cartridge Step 5 : Turn The printer ON If it still does not work you can use the following methods How To Reset MP 258 error 5200 Step 1 : The printer is off and plug the power cord. Step 2 : Press the button STOP / RESET and hold, then press and hold the POWER button Step 3 : POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed. Step 4 : Release both buttons simultaneously Step 5 : The printer will proceed in a while (a while), then the LCD panel will show the number zero (0) Step 6 : Computer will detect NEW DEVICE, Ignore it... Step 7 : Press the power button, then the printer will turn off Step 8 : Press the power button again, then the printer will be ready to use
SOURCE: Canon Printer iP4300 Error B200 How to fix
All my search, b200 error indicates a dead print head.
