I bought a whirlpool tub used. American Standard Model 2732.018.020.
Pump buzzes but will not pump water. What should I do? Do you have a link to that manual?
Are you sure the vacuum line that goes to the air switch is on tight and not leaking or cracked? I have multiiple motors on hand, I was an Am Std Ter. Mgr. Let me know if you resolved your issue or need a motor. Ron
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
Thank you for your reply Mr. gauvreau.
It's working. Poor guy was just accustomed to not turning. I took a screwdriver and showed him how to turn and then he remembered.
button will not turn jets on in tub
will 752538-300 replace 752538-0070a pump om my american standard whirlpool
