SOURCE: Canon i9100
ahh that lights might signifies that some consumable parts of the printer is near end of life like the service station or the waste tank. i suggest that you should download a resetter for that model of printer you have.
SOURCE: tank absorber full and lights blinking
The POWER Lamp Flashes Orange
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used
during print head cleaning. Eight flashes indicates that the waste ink tank is
nearly full. Press the RESUME/CANCEL button to cancel the
error so you can continue printing. Before the waste ink tank becomes completely
full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this
error occurs. Once the waste ink tank becomes completely full, printing will no
longer be possible.
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
SOURCE: Canon S300 printer. 7 orange blinks, 1 green. I
According to the manual found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=330&modelid=6609
7 orange lights represents a bad print head, and the printer will need serviced or replacement. Since printers are so cheap lately, I would just go shopping. Hope this helps! Thanks!
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
