Sharp R-1850A Convection/Microwave Oven Logo
Posted on Jan 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave not heating up
My Sharp R-957M, the microwave, oven, grill not heating up, and turntable not turning. The light and fan are working fine. Any ideas please?.
Ginko
Level 3:
  • Sharp Master 19,396 Answers
  • Posted on Apr 27, 2009
Ginko
Sharp Master
Level 3:
Answers
19396
Questions
25
Helped
8073249
Points
55462
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Sharp - Food not heating up but all is lit up and turn table turns
Hai my friend, if its not heating you must open it at the back and check your fuse on top for contuinity using amultimeter it must be on abuzzer and if its fine there is other fuse covered with normal black cover connected to the cspacitor also check it, if this two fuses are fine check your capacitor if its fine check your magnetron for contunuity of 0,2 ohms but normal if its not heating its fuse, thx
1helpful
My dcs mo-24-Ss microwave oven cannot heat the food after turn on, everything working fine other than no microwave come out
Assuming the turntable, inside light, and internal cooling fan all work when you press "Start" to cook, then I would suspect a bad magnetron, or a bad connection at the "FA" terminal of the magnetron.
If one or more of those three items do not work when you hit "Start", the I would suspect a bad door switch or mount.
The DCS MO24SS is essentially a rebranded Sharp R-530E-series microwave with different cosmetics and a higher price.
The service manual for the Sharp model is here.
The internal Sharp parts in the manual will interchange, but not the external cosmetic parts.
You can order Sharp parts from Encompass here.
Everything works. Time, fan, turntable, light. It
Magnetron and accompanying high voltage diode are usually to blame. Everything else works but the magnetron isn't resonating (providing the proper energy to excite your water molecules).
An appliance repairman can change it for you (typically $180) or you can get a new microwave.
I have a Sylvania Microwave Model SR 11092.When you plug it in it runs but no heat.You have to un plug to stop.Light fan and turntable work fine.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
1helpful
Sharp microwave grill and oven working ok, microwave option not
the magnatron is burnt out they are very expensive to replqace thus i would suggest bying a new microwave
SHARP R 88BKM no microwave
David
This is a sure sign that the MAGNATRON unit has went out on your oven and will need replaced! (This is what cooks the food!)
Please take a second and rate my response!
Thank You!
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
2answers
MICROWAVE RUNNING. DON'T HEAT & TURNTABLE WON'T TURN
your magnatron needs replaced! (It may cost less for a new one then to fix this one!)
1helpful
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
fggfd
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
