Technics SL-1200MK2 Turntable Logo
jesse diaz Posted on Jun 11, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Technics problems My turntable started to drag I haven't tried anything to fix it yet. Any suggestions would be appreciated. Thank you
  • robbo0810 Apr 18, 2008
    the pitch reset lamp fails to illuminate and the platter only runs at one speed regardless of pitch position, and at the same time it tends to hunt, ie it sounds like the record is warped. any idea's? stu.
Anonymous
Level 2:
  • Expert 515 Answers
  • Posted on Sep 02, 2007
Anonymous
Expert
Level 2:
Answers
515
Questions
0
Helped
292977
Points
647
There is no drive belt on this unit. This is a direct drive turntable. Your pitch control might be on it's way out. Are you getting any sort of unusual speed issues? Or is it just sort of running slower than usual? There is a pot you can adjust under the turntable platter to speed it up a bit, however, this is only a temporary fix. It is listed as VR301 - and is on the main board under the turntable platter - it says PITCH on it. Try adjusting that pot, to see if it does anything. WORD OF CAUTION: Make sure your turntable platter is ALWAYS on whenever you power up your turntable, and if you do any electrical modifications, make sure you always disconnect your turntable from it's power source to be on the safe side. If this does not work, then either your pitch control (which is a variable resistor) will need to be replaced. The problem could also be one of the drive components on the main board, however, this will need to be worked on by a service tech. Hope this helps. - Justin
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Jun 11, 2007
Anonymous
Contributor
Level 1:
Answers
32
Questions
Helped
13189
Points
77
One suggestion is to replace the drive belt. Another one is lubricate the bushing located in the center of the table. Good luck.
Problem with unstable pitch in Technics SL 1200 MK2 turntable
Hi Thomas, as you say, it's not the engine, nor the integrated engine
Most likely, the pitchel potentiometer that generates the problem
I would try to clean it, applying a small amount of contact cleaner and test if there are improvements
Keep in mind that it is the Pitch potentiometer that is changing the speed
Comment if the suggestion served
Regards Franco Dosil
Hola Thomas, por lo que comentas, no es el motor, ni el integrado del motor
Lo mas seguro es que el potenciometro de pitch el que genera el problema
Yo intentar?a limpiarlo, aplic?ndole una peque?a cantidad de limpiador de contactos y probar?a si hay mejoras
Ten en cuenta que es el potenciometro de Pitch el que va modificando la velocidad
Comenta si sirvi? la sugerencia
Saludos Franco Dosil
https://www.manualslib.com/manual/387776/Technics-Sl-1200mk2.html
2answers
My player drags in turntable mode
It must be reseted. Try unplug power for ten minutes and replug. If no result check if you can remove its internal small battery and refit.
Technics sl dd33
The power supply of the turntable needs checking. It could be just a fuse or something more serious, such as a faulty transformer.
2answers
Technics sl 1200 dragging
almost often a wrong set table/arm weight and a dirty needle. . i gues the last. Cleanen record
I have a garrard turntable and I'm trying to hook
Connect the turntable wires into the recievers phono input and you should be good to go
Hi I have a Technics SL-350 Turntable System that I bought at a tag sale today. It turns on properly, spins, and you can even slightly hear the sound of the music while it's spinning. However, there is a...
plug a red and white rca cable into the back of the turntable and then plug the other end into your phono output at the back of the amplifier.then turn your selector on your amplifier to phono.wowla you should have sound
3answers
Technics 1210's playing out of one speaker / channel
Have you considered the amp to be the problem? The amp has a magnetic cartridge pre-amp, which only the turntables would use, that can fail. It's often a single IC that has gone.
I have a Sony turntable. Never had a problem. I just started playing records on it recently and it has developed a screeching sound and the turntable slows. I removed the platter and check the belt and...
If it's a mechanical screech you should be able to recreate it by rotating the platter by hand clockwise. Are you saying that did not reveal anything? I'd suspect a foreign object is involved.
EVERYTIME I PLAY A RECORD IT DRAGS TO PICK UP SPEED
Are you sure you have a Technics SL1200MK2 Direct Drive Turntable? If so, then there is a major problem with the drive system. This can only be diagnosed and repaired by a qualified technician.
If your turntable is not the Techics SL1200MK2, and you have no idea what turntable you have, look at the model's label, if it says BELT DRIVE - this is the reason why it drags to pick up speed. If it says DIRECT DRIVE, then take it to a service center for repair.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
2answers
Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
