The Blu-ray player may be in LOCK ON mode, which would prevent the tray from opening.
To switch back to LOCK OFF mode, press 4-8-2-7-3 on the remote control. "Lock Off" will appear in the upper left corner of the TV screen.
Note: If LOCK ON displays instead, then your player was not locked to begin with. Enter 4-8-2-7-3 again to unlock it.
By the way, if you also want to remove the region code on your Blu-rays and DVDs, here Leawo Blu-ray Copy will be recommended. It can not only remove region code, but also copy protection upon discs. In addition, you can use it to copy your Blu-rays and DVDs to other blank discs or digital copies on computer for backup.
If you have Blu-ray discs that you can't play due to the region codes on them, you can try to make a region free copy of your Blu-ray discs. That way you can play the disc on any Blu-ray player. Below's the link that shows you how to create region free copy of your Blu-ray discs using a program called Leawo Blu-ray Copy: How to Make 1 1 Disc to Disc Blu ray Backup with 1 Click Blu ray Copy...
You maybe able to get a region free code from one of these WEB sites.
REGION FREE CODES FOR DVD & BLU-RAY
www.dvdexploder.com/ www.videohelp.com/dvdhacks www.download-info.com/dvd/index_new.htm http://www.dvddemystifiziert.de/codefree_en/codefree.html
