Try looking in the user manual available on this site - Link provided below
http://www.fixya.com/support/p123565-panasonic_kx_t7730_corded_phone/manual-7398
SOURCE: Change the time and date on Panasonic KX-T7730
You have to change from extension 101. Once you are on extension 101 then you need to press program then 0. enter date backwards ie(081104) then day (1=mon 2=tues 3=wed 4=thur 5=fri ect.) then enter time ie(0300 for 3:00) then 0 for am or 1 for pm. so it would go like this
Press program then 0
Enter (example for Tues. Nov. 11,2008 3:00 pm) would be
081104 2 0300 1
then press store then program again and it's set.
SOURCE: Panasonic KX-T7730 corded
If you can provide the phone system type I will try to help as this is a system wide setting and there are a lot of different Panasonic systems out there. ......Mike
SOURCE: Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
SOURCE: Panasonic KX-T7730 - changing time display
Following are the steps:-
PRESS: - PROGRAM (PITS PGM NO. APPEAR)
- *#1234
- 000
- Speaker (Date/Time will appear on the screen & blink
- Point directional sign to the desired position to change accordingly
Once finish with the above - Press "STORE" button
Then lift handset and replace
MT
SOURCE: How can I change the date and time on a Panasonic KX-T7730
From the phone connected to Jack 01 (usually 101) press PROGRAM *#1234 and dial 000 and the SP PHONE button. Your display should show a blinking cursor over the year. Use the FWD and CONF buttons to go forward (and back) and the AUTO ANS or keypad to change the entries. Finish by pressing STORE
Carl
