Hitachi 50UX57B 50" Rear Projection Television Logo
Posted on Dec 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to take hitachi 51 projection tv lense apart?
Anonymous
Level 3:
Top Expert:
  • Hitachi Master 14,553 Answers
  • Posted on Dec 10, 2012
Anonymous
Hitachi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718662
Points
48227
Don't try that if you are talking about one of the three lens, very easy to open the wrong way and have the Glycol come out all over the place and it is toxic.
I know these sets well--just let me first know what the set is doing and not doing!
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Jan 14, 2008
SOURCE: blue haze on hitachi 51" tv
http://www.hdtvoice.com/voice/showthread.php?t=15263
Anonymous
  • 14 Answers
  • Posted on Jan 11, 2009
SOURCE: tv wont power on
I had the same problem Replace the IC's and it should fix this
Anonymous
  • 3459 Answers
  • Posted on Apr 18, 2010
SOURCE: hitachi 51
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Anonymous
  • Posted on May 10, 2010
SOURCE: My Hitachi 52 inch Projection TV video goes one
hitachi 52' tv...the blue color is off...you can put magic focus on and it still want move the blue back where it needs to be
Anonymous
  • 1476 Answers
  • Posted on May 12, 2010
SOURCE: 51"hitachi tv needs convergence module.What would it cost to fix.
Depending on whether your friend's diagnosis is right and whether that is the only problem, perhaps. Certainly if it is free you would have nothing invested beyond the convergence repair. Run it first and make sure that that is the only problem and other than misconvergence it looks good. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to repair it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
1helpful
Firmware update for Hitachi 51F59 51 in. HDTV Television
You need to set up the wireless internet connection in the TV to connect to a wireless router and then the TV will download the firmware update over the internet.
Cleaning lenses on projection tv
Have the set unplugged please.
CAN BE DONE FROM REAR--from the front is a bit tricky and dangerous---from rear with rear cover removed locate the three large black lens( hard to miss them) and clean them with a lens cloth or a paper towel with glass cleaner sprayed on it.
Depending on how much dust===should be done one time a year.
1helpful
Hitachi TV 51 "
Tv is not turning on....you can hear it click....model # 51zx24k Hitachi...
Does my 51swx20b come apart. I need to bring it
if the tv.is projection just take out the back panel
Tv wont power on
Blue haze on hitachi 51" tv
2answers
Hitachi rear projection
bad solder connections on convergance board solder the connections if this does not work then replace them
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
