Maytag Stove / Oven / Range Cooktop - 12001853 Logo
Posted on Dec 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag oven will not heat after self cleaning
Range went to slef clean unexpectly. Turn off power and able to stop. Finally got door open. Now the range will not heat up
Anonymous
Level 2:
Sergeant:
  • Expert 475 Answers
  • Posted on Mar 11, 2013
Anonymous
Expert
Level 2:
Sergeant:
Answers
475
Questions
0
Helped
112325
Points
908
Try to unplug the oven and let it sit for a bit then plug it back in.
2 Related Answers
Anonymous
  • Posted on Dec 05, 2009
SOURCE: high-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Anonymous
  • 43501 Answers
  • Posted on Sep 03, 2010
SOURCE: I have a Maytag range MGR5720BDW, the oven wo't
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
How do I stop the door lock from flashing on my self cleaning oven
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
2answers
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Kenmore self cleaning electric range issue with F10 error during self cleaning mode
You most likely have a failed oven sensor or the control / clock has failed. Self clean mode lets the oven get extremely hot and sometimes causes electronics to fail.
Locked oven
With a heavy wire or coat hanger , slip the wire through the top center of door to hopefully pull latch to the left to release latch.
Unlock door of maytag range model mgr7775ws
unplug the range let it sit for a while then plug it back in.
How do I know when my stove is done self cleaning?
to get all the detailed instructions
just click this link directly
http://www.applianceaid.com/selfclean5.html
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
thanks.
2helpful
How do I lock the oven door, while it's cooking... NOT self clean
You can't. The locks are designed for use when the range is NOT in operation. Teach your child to stay away from the range. Even the new GE ranges with the swing latch, if you use them while the oven is in use, the oven locks until it cools down. Sorry to be blunt, a safety gate to keep baby out of the kitchen will be a good fix.
Jul 30, 2009 • Cooktops
I have a Frigidare range with self cleaning oven. I can't use the oven because it keeps telling me to lock the door, which starts the self cleaning process. If I try to start the oven it tells me the door...
the door lock motor assly could be bad.during self cleaning process the motor runs and locks the door and activates a switch .the control reads the swithch.if motor does not tunrn the door is not closed and it does not activate the switch.at the maximum it could be the control itself gone bad and able to read the switch.but that is less likely.
Jul 28, 2009 • Cooktops
6helpful
Whirlpool self cleaning oven Accubake. 2 yr old
Hi
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Top Maytag Cooktops Experts
Paul Carew
Stan Ford
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
