SOURCE: HP Pavilion dv9000 Entertainment PC
I have had to send my laptop to Hp for the same problem.
Go to this page and see if your unit qualifies for the " HP Limited Warranty Service Enhancement"
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: hp pavilion dv 4-1125 nr entertainment pc xp
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3795293&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Click the link for driver download page
SOURCE: hp pavilion dv 4-1125 nr entertainment pc xp auideo drivers
IF YOU HAVE DISK INSERT IT AND INSTALL ....IF YOUVE DOWNLOADED THE DRIVERS CLICK ON THE PACKAGE WHICH IS A SELF EXTRACTING FILE AND INSTALL FILES ONCE EXTRACTED.
SOURCE: need to replace keyboard in HP Pavilion dv6626us
Turn the computer off and close the computer lid.
Remove the battery and the AC power supply.
1st we need to remove the switch cover or keyboard bezel. This is plastic strip that runs above the keyboard.
Turn the computer upside down with the front panel towards you.
Remove the three Phillips screws that secure the switch cover to the computer.
Turn the computer display-side up with the front toward you.
Open the computer as far as possible.
Lift the rear edge of the switch cover and swing it forward until it rests on the keyboard.
Release the zero insertion force (ZIF) connector to which the LED board cable is connected and disconnect the cable from the LED board.
Remove the switch cover.
Now remove the panel directly above the battery compartment and remove the 2 keyboard screws there and another 2 screw in the battery compartment (they should me marked with icons of keyboards)
Turn the computer display-side up with the front panel towards you.
Lift the rear edge of the keyboard until it rests at an angle.
Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover.
Swing the keyboard forward until it rests on the palm rest.
Release the ZIF connector to which the keyboard cable is connected and disconnect the keyboard cable from the system board.
Remove the keyboard.
Just reverse the procedures to replace everything.
Good luck.
