HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
A
Anonymous Posted on Dec 09, 2012
Hp slimline s5000 dead motherboard
I have a hp slimline 5000 the power turns but np picture the fans go off but the power supply and the cd rom stay on. have reset cmos have tried different monitor,have removed the memory and replaced.
HP Pavilion Slimline s5000 (s5100z)
fans spin, ok,
DVD tray enjects.
does this PC have the optional
the first 5000 was made in year 2003
then laters for VISTA.
id have to see your service tag info to wax smarter.
hp forum can help try that? hp.com
I guess the VGA port is dead, ?
most old PC had 2 ports, 1 on the card, one on the main chassis rear . if the card GPU vga is present only it works.
if you remove the GPU the main VGA port is live.
I cant see rear of your PC and seeing MATTERS.
the common failures are:
RTC coin cell dead.
HDD bad, (most are this old)
and PSU bad.
in that order.
What memory does a Pavilion Slimline S5000 PC use DDR, DDR2, DDR3?
that's easy but no full model told
quotes (sales)_
"HP launching its new s5000 series in June of 2009
In total there are eleven HP Slimlines which have been released "then !
learn to read the service tag first
read the true model name and product ID
then answer be accurate
the what matters is the CPU it uses and what north bridge it has.
and some bridges do ddr2 and 3 but the maker chose 1 or the other..
See, and PC are not the same sold all over the earth.
not told that ether,
old g41 chip set if intel version/
if is g41 it does in fact support DDR2 and 3.
only HP decided what to use, only them, their DESIGN
no model told at all
S5xyz1 , zyz1 not told at all so not answer easy.
ever./
or go to Hp.com
click support and tell real model now.
and RTM
s5305z, s5310t, s5350z, s5370t, s5380t, s5730f, s5220y
s5530 and more. endless it seems.
S5510,s5100br,5507,5160 5260 and more, lost more and more world wide,
worst of all support ended HP'
and wiki says it loves to overheat.
the end letter are for country or sold in special stores, like walmart bestbuy,
all numbers in the model or product ID matter, stated on he service tag.
What are power supply specs for hp Slimline s5200z
HP say only that the psu is rated at 220W
(http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c01911671&lc=en&jumpid=reg_r1002_usen_c-001_title_r0002#N121)
I
I rather think the specs are the same as this one and that themodel number is the model in yours
http://www.ebay.co.uk/itm/HP-Pavilion-SlimLine-s5000-220W-PSU-Power-Supply-HP-P-N-504965-001-PC8044-/221182783648
HP Pavilion SlimLine s5000 220W PSU Power Supply HP P/N: 504965-001 taken from computer when hard drive died in full working order has been cleaned ready to be reinstalled Model:PC8044 HP P/N:504965-001 AC INPUT:100-240V, 50/60HZ, 6A DC OUTPUT: +3.3V 16A +5.08V 15A TOTAL110W MAX +12.0V 16A TOTAL210W MAX -12.0V 0.3A +5.08Vsb 2.0A
However to certain take the panel off yours and have a look at yours
The are plenty of higher power replacements available search the internet for eg "what psu is in a hp s5200z"
20.December.2014
Broken sata connecter
If you mean on the motherboard then yes. if you can find an empty one.
Terry
Video card upgrade for HP Slimline S5000 model s5570t
that power supply is going to limit you a bit also you will have to use a low profile card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814129164
Ati 54xx series are going to be your ticket to energy efficient and direct x 11 also tend run cooler then its nvidia counter parts
Computer is dead. hp slimline. anything I can do to jump start it.
A Totally dead PC can usually mean that the the power supply has quit.
If you've ever replaced a power supply
in a desktop (or Slimline) PC, it takes about an hour, but if its your first time, take your time, and
allocate half a day.
3 vital tips:
(1) use proper anti-static techniques, just in case you might happen to touch the motherboard or a card in the option card backplane.
(2) get (or order online) a replacement power supply with a wattage rating equal to or greater than the wattage rating of power supply being replaced - so you can be sure that the new power supply will handle the load offered by your system.
(3) always keep the power supply module from old PCs - they can come in handy when one dies in a PC that you really want to run (even though the older ones dont have the SATA connectors).
How do I get audio/sound on my HP pavilion slimline s5000 series?
Hi there!
HP has a lot of computer model under the s5000 series.
You can click on this website and choose the exact model of your HP Pavilion computer. After that, you can click on the Software & Driver Downloads. You will be directed to a page where you need to choose the operating system file of your computer. Once you're done with that, you can download all the drivers compatible with your computer, including the audio driver.
Hope this helps.
3answers
Slimline s3100n keeps shuttubg down
scan for viruses. maybe it is infected. if still, do the recovery options for hp.
My father just bought a HP s5000 slimline. He
hmm.. in that model many model right now is you need to buy usb port keyboard and mouse
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
