Question about Dell PowerEdge Computers & Internet
Dell poweredge 2650 solid amber light
Solid amber front caution light , no errors on LCD , no other indicators lit. Power supplys = good both green , already swapped to be sure. Rear case fans seem to be running on high. All internal fans working and unit is not hot , nor ever taxed. Solid amber indicator is not in dell manual , Any ideas??
  • 356 Answers
Go here and enter the service tag of your server and download dell open manage server administrator managed node. once installed it will tell you exactly what the problem is. i believe the current version of OMSA is 7.1
Posted on Jan 06, 2013
5 Suggested Answers
SOURCE:
  • 37 Answers
SOURCE: I have multiple PowerEdge 2650's.. the NIC1
data is being moved when flashing long way to look over for watching the display activity
Dell Poweredge servers are great
Posted on Oct 27, 2009
  • 259 Answers
SOURCE: Bootup Problem - Dell Poweredge 2650
Process of elimination? I first thought it may be a power problem but I could not understand the LED flashing (It still maybe a power problem) If you can leave on charge for 4-5 hours more if you can make sure the light is not flashing (That is turn the laptop off at the power switch) Try turning on after being on charge for as long as you can If that does not work it may be the bios with the wrong setting or the Hard Drive is faulty (The more I think about it I think it may the the last issue) Try the other steps first the turn on holding the DELETE button it (I think that is the button to access the bios ) This with work if the Hard is Good or bad)
Posted on Jan 23, 2009
  • 12 Answers
SOURCE: We have a Dell Poweredge
Go into the RAID setup during bootup (not always in the BIOS), but will post somewhere on startup (should say SCSI/SAS Controller card press CTRL + M to enter setup) or similar.
When in the raid setup check to see the status of the drive(s).
Was the machine running and it's just happened etc or are these machines you have obtained and are plain not working?
Posted on Sep 09, 2010
SOURCE: dell poweredge 830 server orange flashing light
its the cover switch. there is a small push switch on the front panel that detects if the front cover has been removed, either the switch is defective, or the cover is not seating properly to close the switch.
Posted on Sep 30, 2010
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
Dell poweredge t110 server Amber error light on front panel blink one time
Had the same thing happen to me today and in my case it was a code 18 as they come...
It started while I was installing a video card adapter for a dual monitor setup. The solution - I had to simply close the side panel I had left open for testing and then reboot the server. The intrusion alarm went off.
Feb 02, 2012 | Dell PowerEdge T110 Server (GB/2GB)...
My dell poweredge 1800 doesnot boot, it gives an amber light after turning on . I have tried to remove the Ram but still the problem persists
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.May also be caused by a defective card installed in the motherboard, i.e. video card.
Jan 31, 2012 | Dell PowerEdge 1800 Server
I have a blue vertical flashing light showing just above the Dell emblem. In the past there has been a solid light. I have checked on OpenManager which indicates all is well but I do not like unexplained...
Great thanks,
That's just a system indicator flash. Solid blue means on and normal, blinking means someone either turned on the system indicator in the management software or bumped the indicator switch on the back of the server. This was designed to make easier transitions from back to front when working with multiple servers in a rack. To turn the indicator off, just go to the back of the server and find the Ethernet and usb ports that are together. If the usb is the bottom and Ethernet port is the top then just to the right you should see a small blue blinking light and a button, pushing the button wil turn the blinking off.
Again, no worries this is just a "locator beacon" not an error message, if the light ever blinks yellow then you have an issue.
Hope this helps FixYa,
Chris
Jan 10, 2011 | Dell PowerEdge 1800 Server
I recently had a power outage for about an hour. My desktop was protected by a surge protector. After the power came on, my computer won't power up and there's no power light. However, there is a blinking...
if the system will not power on, I would suggest a new power supply as the first troubleshooting option as they are about 1/3 the price of the motherboard. The Flea Power indication on the motherboard only indicates power is reaching the board, not if all needed voltages are being received.
Normally on a Dell, if you are getting power then when you attempt to power on, you usually get a power LED indication on the power button. Solid Green/Blue is normal, Flashing Amber is Power supply bus failure, Solid Amber is normally a motherboard.
If you haven't bypassed the UPS and connected direct to the outlet, I would try that 1st, as the UPS could be the failure too.
Dec 23, 2010 | Dell XPS 200 PC Desktop
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Poweredge 2600 power supplies in red
Possibly a power distribution board problem.
PDB requires replacement.
Jul 09, 2008 | Dell PowerEdge 2600 Server
Computers & Internet Logo
514 people viewed this question
Ekse
Clive
Clive
