SOURCE: gyropter not lifting off after full charge
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
SOURCE: My gyropter will not shut off. The blades keep
definetly a short circuit some were in the copter itself
There pretty good about returning those items they can be a lot of fun good luck james
Testimonial: "Thank you. Will be returning it and hope they have some more left. It would be fun if everything works. Thanks again."
