Question about Mitsubishi VS-50111 50" Rear Projection Television
Overscan when playing xbox on 1080i hd setting it cuts off all four sides of the picture by about 2 inches. its really annoying because it cuts off text in some games. is there away to fix the overscan?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Yes, if you have the original remote and get into the adjustment menu which is hidden you can adjust width, height, and centering if you want.
Posted on Dec 10, 2012
5 Suggested Answers
SOURCE:
sandrew
  • 2961 Answers
SOURCE: HD resolutions
Your TV would have to be HD ready and will automatically set itself to 1080i, but if you go into the XBOX 360 console settings' the top menu enables you to change resolution, but if the x box does not recognise 1080i it will not show up. See if 720i shows up as this is still High Def. and also that 60 Hertz is the setting and not 50 hertz
Posted on Dec 30, 2006
salt56
  • 373 Answers
SOURCE: overscan
For Factory Menu, press MENU 1 3 7 0
Service Adjustment Mode, press MENU 2 3 5 7
Convergence Mode, press MENU 2 3 5 9
Use the VIDEO or VIDEO buttons to enter two different groups of adjustments
Use the VIDEO / VIDEO buttons to toggle thru the adjustments
Use the + and - keys to adjust
When finished with adjustments, press ENTER to save
Press MENU twice to exit service mode
Hope this helps. You should look for the vertical height or size adjustment. Do not adjust anything you don't know about.
Posted on Dec 28, 2007
  • 38 Answers
SOURCE: philips 1080i xbox 360 hook up
you need to change the settings on the xbox aswell.
go to your settings menu and change the picture settings to 1080i
Posted on Oct 27, 2008
  • 121 Answers
SOURCE: Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Posted on Feb 25, 2009
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
Jan 30, 2009 | Mitsubishi WS-55857 55" Rear Projection...
Philips 1080i xbox 360 hook up
Oct 27, 2008 | Mitsubishi WS-55857 55" Rear Projection...
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Display to big with PS3
All CRT RPTVs have overscan, and some sources bring this out more than others.
It can always be cured to at least be able to see the needed parts of the pic, but hoses your picture beyond belief, and correcting that takes time, experience, patience and expertise.
I do overscan reduction on all CRT RPTVs as part of what my calibrations offer, but charge extra to do so.
Mr Bob
Feb 02, 2008 | Philips 60PP9352 60" Rear Projection...
Hitachi 53SDX89BA HD settings
Problem more than likely with the xbox, as the output stream of data from the game platform is not always consistent...accordianman
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Using Hitachi's 53SDX89BA High-def settings w/ HD-DVD
look at these see if this helps
http://www.hdtvoice.com/voice/showthread.php?t=16973
http://www.hdtvoice.com/voice/showthread.php?t=8721
Most HDTVs cannot properly stretch incoming HD signals, however, if the programme is true HD, you should not much of the image off-screen - most new HDTVs have about 2% overscan and the tickers should be on screen when watched in the appropriate stretch mode.
See:
http://www.hdtvoice.com/voice/showthread.php?t=1044 and
http://www.hdtvoice.com/voice/showthread.php?t=1052
Xbox
what HD is your TV? 720p, 1080i, or 1080p? have you tried using all these HD settings?
Dec 26, 2007 | Microsoft Xbox 360 Console
Hitachi 53SDX89BA
I also have a Hitachi 53SDX89BA and I bought it with the same assumption as you: that it's HD ready. The specs in the manual states the following: "Full 1080i HDTV Capatable with Set-Top Box". I beleive this means that it does not include an HD tuner, but that it is capable of handling up to 1080i resolution. Normal (non-HD) resolution on this TV is 480i.
So here's my problem: Until recently, I wasn't using the HD settings on this TV because I don't have a set top box, nor do I subscribe to any HD content from my cable provider. However, I just purchased an XBox 360 along with an XBox 360 HD-DVD player (it's an XBox peripheral that works with the game console). The Xbox asks you to choose the resolution output (480i, 720i or 1080i) to match your TV's HD capabilities. When I select 1080i output and change my TV's settings to receive an HD signal, the picture quality is amazing. However, the video signal seems to get lost ocassionally (i.e. TV picture gets scrambled) but then it comes right back. This does not happen when I select a 480i output on the Xbox...but of course, the picture isn't as crisp and clear as a 1080i picture.
I don't know if this is a problem with the TV or with the Xbox. Has anybody else had this problem??
Dec 06, 2007 | Hitachi 50UX57B 50" Rear Projection...
Overscan Problem
Switch to that input, and run the Auto Convergence for that input (Setup menu on the TV, Convergence). Convergence settings save for that particular input.
Dec 06, 2007 | Televison & Video
Cutting off the picture
please try once more in the memu on tv
Oct 14, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Mitsubishi VS-50111 50" Rear Projection Television Logo
540 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
