HP Support > Compaq Presario CQ56-115DX Notebook PC > Manuals,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4308201&
I would like you to click on -
Compaq Presario CQ56 Notebook PC and HP G56 Notebook PC - Maintenance and Service Guide
This is a PDF file.
It may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
At the top of the PDF file is the page number box.
It is to the right of the down arrow.
This is the page number I will be referring to, and not the manual's actual page.
Go to Page 46.
(In the Bookmarks menu on the left, click,
1) On the + sign to the left of Removal and replacement procedures
2) On the + sign to the left of Component replacement procedures
3) Keyboard )
A) Remove ALL power to the laptop.
Remove the AC adapter (Charger) and Battery.
B) Remove the Memory Compartment Cover.
C) Computer upside down (Bottom facing up), front side toward you,
remove the 6 Philips head screws indicated.
D) Computer back to it's normal position, (Right side up) use a thin, flat bladed screwdriver, and EASE up on the Right and Left BACK edges of the Keyboard.
NOTE*
There are plastic tabs on the Keyboard in the front. (Towards you) These can be broken off if you use the thin, flat tipped screwdriver TOO close to the Front.
The BACK of the Keyboard is lifted up to a 45 degree angle, then the Keyboard is slid back towards the LCD screen, a little. This frees the tabs from the Palm Rest (Top Cover) of the laptop.
NOTE*
The Keyboard is attached TO the motherboard by the Keyboard Cable.
The Keyboard Cable does not come off of the Keyboard.
After the tabs are freed, the Keyboard is rolled over, and laid on it's keys, on the Palm Rest.
This allows both hands (Fingers) to remove the Keyboard Cable from the connector on the motherboard.
The connector on the motherboard is a ZIF connector.
Zero Insertion Force.
The connector is a rectangular block of plastic, and is composed of two pieces.
The top smaller part moves away from the larger bottom part.
The two pieces DO NOT come completely apart. They do not completely separate from each other.
The top part slides away from the bottom part, but only so far. (1/8th inch?)
The cable coming from the Keyboard is a FFC.
Flat Flex Cable.
It has NO connector on the end that plugs into the motherboard.
Just a flat ribbon cable with exposed contacts.
MAKE SURE you line the new Keyboard's cable up the SAME WAY as the old Keyboard's cable.
Install in the same direction.
(Even if the cable is twisted over)
The ZIF connector's top part locks the FFC in place, when the ZIF connector is closed.
The top part has a wedge design.
For additional questions please post in a Comment.
Regards,
joecoolvette
